Shutdown like normal, click Power off in Windows. Not a hard/forced shutdown. It boots fine after hard/forced shutdown (until a drive is added/removed).
Samsung 850 Pro SSDs 512GB & 256GB
How do you mean? the windows installer choses this automatically right?
Running repair using the new iso you shared works wonders in fixing boot up. Thanks.
Now to return to solve my remaining driver issues
To specify the type of GUIID for the Windows Bootable USB, you can use Rufus. The Windows Media Installation Tool looks at what you currently have on the machine and sets it accordingly, probably. Since you can boot with CSM disabled, it means that you already have a GPT partition table on the boot disk. You can convert the other one with Rufus, or AOMEI Partition Assistant easily.
Oh, I wasn’t referring to the USB. The issue was with the SSD. OK here’s the setup.
The Win10 installer will configure the partition on the target SSD accordingly (I haven’t used gparted
or some such to see whether it is a GPT partition or not…).
In any case, the Win 10 recovery USB (made via the ISO link you provided), helped a lot as this allowed me to run a recovery step to “repair” the host OS.
At full load, I’m seeing over 200W off the i7-11700K, this is crazy given it is a 125W TDP part. Wow!
Depending on if the installation media uses MBR/GPT specifically for Windows, that’s how it configures the drive it is being installed to.
The final fix to all my issues was upgrading the BIOS and Win 10 to 20H2. I didn’t have to install any further drivers, everything was automatically resolved.
Thanks for your help @eray appreciatd.
When things go wrong, use Win 10 ISO on a USB to repair OS on boot drive.
