And so comes the tenth version of Debian (EDIT: actually fifteenth, but it’s called Debian 10 - They’re going pentadecimal maybe?) . Some important notes for this release:
over 13370 new packages, for a total of over 57703 packages
– New things with this release:
Secure Boot now supported using shim
Live ISOs ship with Calamares and Debian Installer
/bin, /sbin and /lib are merged into /usr
AppArmor installed and enabled by default
Optional APT hardening
LUKS2 added and enabled by default
nftables replaces iptables as the default firewall
Automatic Updates enabled for all updates
Driverless printing with CUPS 2.2.10
GNOME on Wayland is used by default
– Important issues:
Legacy network interface names are not fully deprecated and should be updated
OpenSSL’s default minimum TLS level has been raised from TLSv1 to TLSv1.2
People using channel bonding/dummy interfaces should beware of systemd installing /lib/modprobe.d/systemd.conf which may cause an override in the configuration.
SysV init no longer supported
Existing PostgreSQL databases need to be reindexed
gnome-disk-utility fails to change LUKS password causing permanent data loss
evolution-ews has been dropped, and email inboxes using Exchange, Office365 or Outlook server will be removed
Calamares installer leaves disk encryption keys readable
** solvable by adding UMASK=0077 to /etc/initramfs-tools/conf.d/initramfs-permissions and running update-initramfs -u
Some deprecated packages worth mentioning:
phpmyadmin, ipsec-tools, ssmtp, ecryptfs-utils
Fun fact about Debian. Part of the name comes from the name Debra. She is one of the ex’es of the guy who started this project. Another part from the name Ian.(The founder) But also the story of the guy himself is kinda dark…
Thats a fucking joke at this point. Okay Ill be the first to say debian is rock solid stable but god damn.. No linux 5 like not even just 5.1.16 and make it LTS for debian (its destined to be the next LTS kernel).. like thats just come on debian..
This is why I am on fedora but hey debians great for stability and sys admin work man.. Good platform cant hate too much.. good to see they finally moved on from 9 and are moving away or closer to the end of kernel 4
Don’t worry about that. It’ll show up in the backports repo eventually. In the meantime, if you want to run the bleeding edge kernel, take a look at liquorix.
GNOME on Wayland is used by default.
Darn, I was going to try Debian on my next desktop. I guess I will have to stick to Linux Mint or Ubuntu to keep compatibility with X11.
