Hi guys. I am worried. This is my first build. I have an MSI B450 Tomahawk. Last night, while installing the motherboard, it slipped off the standoffs rather violently and there is what I would describe as a dent or a gouge on the chipset heatsink (the mobo hit the sharp edge of the drive bays). I am building the pc slowly; I purchase a new part with each paycheck. That being said, I cannot validate whether damage has been done or not. I don’t care if the damage is cosmetic, but does anyone think that it could be worse than just an unsightly gouge? The build is contained in a CORSAIR Carbide 100R Silent, so it won’t be seen anyway. Thanks for your input!
Hey, welcome to the forum… Stay away from the furries and it will all be fine…
On topic, does the board function? If it works I don’t see any reason to be worried. If nothing else this dent gives the heatsink extra surface area to radiate the heat…
Seriously, though, if the only damage is the heatsink I see no reason why the board wouldn’t work…
I don’t think he got the all the parts yet
That’s assuring, thank you! Thus far, I have the following:
*AMD Ryzen 2700x
*Wraith Prism Stock CPU Cooler
*CORSAIR Carbide 100R Silent
*MSI B450 Tomahawk
*Thermal Grizzly Kryonaut
That being said, I cannot test anything yet. Also, I am really unsure what type of GPU I need. Therefore, I am really trying to consider what I need the GPU to do.
if the only damage is the shiny bit on the heatsink, you’ll be fine.
If it gauged any PCB bid, then it might be dicey
Correct, not yet. Slowly but surely it’s getting there.
You don’t have an old gpu to throw in there to just test out?
Nope, this is my first build.
or borrow off a mate / relative
Ayyyy. I knew the feeling of building my first PC.
I appreciate your input! I think it’s just the shiny bit.
I doubt it’s a problem. Seems superficial to me.
Good luck with the build.
You still remember that? Was it even in color back then?
Were there valves involved?
Nixie tubes?
Steam?
Thanks everyone for chiming in. It’s that I have been trying to be very meticulous with part selection, but once it came to the assembly, I am learning as I go. I had dropped a screw in the case, and was trying to shake it out, but I forgot that I had unfastened the mobo to do some cable management, and it just popped off the standoffs and crashed into the sharp edge on the drive bays.
Keep your finger tip on the side of the screw as you guide it in. You could also magnetize your screwdriver yourself.
That’s a good solution. Thanks!
This is hardware, dude, not gaming thread
Thanks for the wellwishing! I’m glad you believe it’s superficial because, if it is, it won’t be visible. As I said earlier, I have the CORSAIR Carbide 100R Silent, so there’s no window, and I plan to keep it under the desk, anyway!
Haha! I think they were trying to make a joke. Like, “really, you remember your first build?”, as if that was so long ago that the computer ran off steam and valves. That’s the way I read it…
I went the opposite route and made my computer as flashy as I could
