Hi
I have successfully created a KVM, and i’m trying to follow this guide on how to do cpu pinning.
In their example XML code i see that they are passing the vCPU, and then the next thing that is written a cpuset. I don’t quite understand what this is, and how it correlates in this way in their example.Could anyone please help me a bit here?
Here is my cpu layout, and I want to pass through everything but core 0. Which is then every vCPU except 0 and 16. But how should my xml look like then?
my: lscpu -e
CPU NODE SOCKET CORE L1d:L1i:L2:L3 ONLINE MAXMHZ MINMHZ
0 0 0 0 0:0:0:0 yes 3500,0000 2200,0000
1 0 0 1 1:1:1:0 yes 3500,0000 2200,0000
2 0 0 2 2:2:2:0 yes 3500,0000 2200,0000
3 0 0 3 3:3:3:0 yes 3500,0000 2200,0000
4 0 0 4 4:4:4:1 yes 3500,0000 2200,0000
5 0 0 5 5:5:5:1 yes 3500,0000 2200,0000
6 0 0 6 6:6:6:1 yes 3500,0000 2200,0000
7 0 0 7 7:7:7:1 yes 3500,0000 2200,0000
8 0 0 8 8:8:8:2 yes 3500,0000 2200,0000
9 0 0 9 9:9:9:2 yes 3500,0000 2200,0000
10 0 0 10 10:10:10:2 yes 3500,0000 2200,0000
11 0 0 11 11:11:11:2 yes 3500,0000 2200,0000
12 0 0 12 12:12:12:3 yes 3500,0000 2200,0000
13 0 0 13 13:13:13:3 yes 3500,0000 2200,0000
14 0 0 14 14:14:14:3 yes 3500,0000 2200,0000
15 0 0 15 15:15:15:3 yes 3500,0000 2200,0000
16 0 0 0 0:0:0:0 yes 3500,0000 2200,0000
17 0 0 1 1:1:1:0 yes 3500,0000 2200,0000
18 0 0 2 2:2:2:0 yes 3500,0000 2200,0000
19 0 0 3 3:3:3:0 yes 3500,0000 2200,0000
20 0 0 4 4:4:4:1 yes 3500,0000 2200,0000
21 0 0 5 5:5:5:1 yes 3500,0000 2200,0000
22 0 0 6 6:6:6:1 yes 3500,0000 2200,0000
23 0 0 7 7:7:7:1 yes 3500,0000 2200,0000
24 0 0 8 8:8:8:2 yes 3500,0000 2200,0000
25 0 0 9 9:9:9:2 yes 3500,0000 2200,0000
26 0 0 10 10:10:10:2 yes 3500,0000 2200,0000
27 0 0 11 11:11:11:2 yes 3500,0000 2200,0000
28 0 0 12 12:12:12:3 yes 3500,0000 2200,0000
29 0 0 13 13:13:13:3 yes 3500,0000 2200,0000
30 0 0 14 14:14:14:3 yes 3500,0000 2200,0000
31 0 0 15 15:15:15:3 yes 3500,0000 2200,0000
Here is the xml code that has me confused
<vcpu placement='static'>8</vcpu>
<iothreads>1</iothreads>
<cputune>
<vcpupin vcpu='0' cpuset='2'/>
<vcpupin vcpu='1' cpuset='8'/>
<vcpupin vcpu='2' cpuset='3'/>
<vcpupin vcpu='3' cpuset='9'/>
<vcpupin vcpu='4' cpuset='4'/>
<vcpupin vcpu='5' cpuset='10'/>
<vcpupin vcpu='6' cpuset='5'/>
<vcpupin vcpu='7' cpuset='11'/>
<emulatorpin cpuset='0,6'/>
<iothreadpin iothread='1' cpuset='0,6'/>
</cputune>
<topology sockets='1' cores='4' threads='2'/>
I don’t understand why their “cpuset” seems to be so random. From their lscpu -e output
0 0 0 0 0:0:0:0 yes 4600.0000 800.0000
1 0 0 1 1:1:1:0 yes 4600.0000 800.0000
2 0 0 2 2:2:2:0 yes 4600.0000 800.0000
3 0 0 3 3:3:3:0 yes 4600.0000 800.0000
4 0 0 4 4:4:4:0 yes 4600.0000 800.0000
5 0 0 5 5:5:5:0 yes 4600.0000 800.0000
6 0 0 0 0:0:0:0 yes 4600.0000 800.0000
7 0 0 1 1:1:1:0 yes 4600.0000 800.0000
8 0 0 2 2:2:2:0 yes 4600.0000 800.0000
9 0 0 3 3:3:3:0 yes 4600.0000 800.0000
10 0 0 4 4:4:4:0 yes 4600.0000 800.0000
11 0 0 5 5:5:5:0 yes 4600.0000 800.0000
I have also tried using this command to get some sens as of what cpu set fits where, and tried the xml code below, with horrible results.
virsh capabilities | grep “cpu id”
<cpu id='0' socket_id='0' die_id='0' core_id='0' siblings='0,16'/>
<cpu id='1' socket_id='0' die_id='0' core_id='1' siblings='1,17'/>
<cpu id='2' socket_id='0' die_id='0' core_id='2' siblings='2,18'/>
<cpu id='3' socket_id='0' die_id='0' core_id='3' siblings='3,19'/>
<cpu id='4' socket_id='0' die_id='0' core_id='4' siblings='4,20'/>
<cpu id='5' socket_id='0' die_id='0' core_id='5' siblings='5,21'/>
<cpu id='6' socket_id='0' die_id='0' core_id='6' siblings='6,22'/>
<cpu id='7' socket_id='0' die_id='0' core_id='7' siblings='7,23'/>
<cpu id='8' socket_id='0' die_id='0' core_id='8' siblings='8,24'/>
<cpu id='9' socket_id='0' die_id='0' core_id='9' siblings='9,25'/>
<cpu id='10' socket_id='0' die_id='0' core_id='10' siblings='10,26'/>
<cpu id='11' socket_id='0' die_id='0' core_id='11' siblings='11,27'/>
<cpu id='12' socket_id='0' die_id='0' core_id='12' siblings='12,28'/>
<cpu id='13' socket_id='0' die_id='0' core_id='13' siblings='13,29'/>
<cpu id='14' socket_id='0' die_id='0' core_id='14' siblings='14,30'/>
<cpu id='15' socket_id='0' die_id='0' core_id='15' siblings='15,31'/>
<cpu id='16' socket_id='0' die_id='0' core_id='0' siblings='0,16'/>
<cpu id='17' socket_id='0' die_id='0' core_id='1' siblings='1,17'/>
<cpu id='18' socket_id='0' die_id='0' core_id='2' siblings='2,18'/>
<cpu id='19' socket_id='0' die_id='0' core_id='3' siblings='3,19'/>
<cpu id='20' socket_id='0' die_id='0' core_id='4' siblings='4,20'/>
<cpu id='21' socket_id='0' die_id='0' core_id='5' siblings='5,21'/>
<cpu id='22' socket_id='0' die_id='0' core_id='6' siblings='6,22'/>
<cpu id='23' socket_id='0' die_id='0' core_id='7' siblings='7,23'/>
<cpu id='24' socket_id='0' die_id='0' core_id='8' siblings='8,24'/>
<cpu id='25' socket_id='0' die_id='0' core_id='9' siblings='9,25'/>
<cpu id='26' socket_id='0' die_id='0' core_id='10' siblings='10,26'/>
<cpu id='27' socket_id='0' die_id='0' core_id='11' siblings='11,27'/>
<cpu id='28' socket_id='0' die_id='0' core_id='12' siblings='12,28'/>
<cpu id='29' socket_id='0' die_id='0' core_id='13' siblings='13,29'/>
<cpu id='30' socket_id='0' die_id='0' core_id='14' siblings='14,30'/>
<cpu id='31' socket_id='0' die_id='0' core_id='15' siblings='15,31'/>
XML code for implementing cpu pinning
<cputune>
<vcpupin vcpu="0" cpuset="1"/>
<vcpupin vcpu="1" cpuset="17"/>
<vcpupin vcpu="2" cpuset="2"/>
<vcpupin vcpu="3" cpuset="18"/>
<vcpupin vcpu="4" cpuset="3"/>
<vcpupin vcpu="5" cpuset="19"/>
<vcpupin vcpu="6" cpuset="4"/>
<vcpupin vcpu="7" cpuset="20"/>
<vcpupin vcpu="8" cpuset="5"/>
<vcpupin vcpu="9" cpuset="21"/>
<vcpupin vcpu="10" cpuset="6"/>
<vcpupin vcpu="12" cpuset="22"/>
<vcpupin vcpu="13" cpuset="7"/>
<vcpupin vcpu="14" cpuset="23"/>
<vcpupin vcpu="15" cpuset="8"/>
<vcpupin vcpu="16" cpuset="24"/>
<vcpupin vcpu="17" cpuset="9"/>
<vcpupin vcpu="18" cpuset="25"/>
<vcpupin vcpu="19" cpuset="10"/>
<vcpupin vcpu="20" cpuset="26"/>
<vcpupin vcpu="21" cpuset="11"/>
<vcpupin vcpu="22" cpuset="27"/>
<vcpupin vcpu="23" cpuset="12"/>
<vcpupin vcpu="24" cpuset="28"/>
<vcpupin vcpu="25" cpuset="13"/>
<vcpupin vcpu="26" cpuset="29"/>
<vcpupin vcpu="27" cpuset="14"/>
<vcpupin vcpu="28" cpuset="30"/>
<vcpupin vcpu="29" cpuset="15"/>
<vcpupin vcpu="30" cpuset="31"/>
<emulatorpin cpuset="0,16"/>
<iothreadpin iothread='1' cpuset='0,16'/>
</cputune>
Current running XML code for my entire VM.
<domain type="kvm">
<name>win10</name>
<uuid>95b97836-0676-47d8-b234-75fa569d8a1b</uuid>
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://microsoft.com/win/10"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">16384000</memory>
<currentMemory unit="KiB">16384000</currentMemory>
<vcpu placement="static" current="20">32</vcpu>
<os>
<type arch="x86_64" machine="pc-q35-5.0">hvm</type>
<loader readonly="yes" type="pflash">/usr/share/edk2-ovmf/x64/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/win10_VARS.fd</nvram>
</os>
<features>
<acpi/>
<apic/>
<hyperv>
<relaxed state="on"/>
<vapic state="on"/>
<spinlocks state="on" retries="8191"/>
<vendor_id state="on" value="something"/>
</hyperv>
<kvm>
<hidden state="on"/>
</kvm>
<vmport state="off"/>
<ioapic driver="kvm"/>
</features>
<cpu mode="host-passthrough" check="partial">
<topology sockets="1" dies="1" cores="16" threads="2"/>
</cpu>
<clock offset="localtime">
<timer name="rtc" tickpolicy="catchup"/>
<timer name="pit" tickpolicy="delay"/>
<timer name="hpet" present="no"/>
<timer name="hypervclock" present="yes"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type="block" device="disk">
<driver name="qemu" type="raw"/>
<source dev="/dev/nvme0n1"/>
<target dev="vda" bus="virtio"/>
<boot order="1"/>
<address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</disk>
<disk type="file" device="cdrom">
<source file="/home/matrucious/Downloads/virtio-win-0.1.171.iso"/>
<target dev="sda" bus="sata"/>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="0"/>
</disk>
<controller type="usb" index="0" model="qemu-xhci" ports="15">
<address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
</controller>
<controller type="sata" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
</controller>
<controller type="pci" index="0" model="pcie-root"/>
<controller type="pci" index="1" model="pcie-root-port">
<model name="pcie-root-port"/>
<target chassis="1" port="0x10"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="2" model="pcie-root-port">
<target chassis="2" port="0x11"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
</controller>
<controller type="pci" index="3" model="pcie-root-port">
<target chassis="3" port="0x12"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
</controller>
<controller type="pci" index="4" model="pcie-root-port">
<target chassis="4" port="0x13"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
</controller>
<controller type="pci" index="5" model="pcie-root-port">
<target chassis="5" port="0x14"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
</controller>
<controller type="pci" index="6" model="pcie-root-port">
<target chassis="6" port="0x8"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="7" model="pcie-root-port">
<target chassis="7" port="0x9"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x1"/>
</controller>
<controller type="pci" index="8" model="pcie-to-pci-bridge">
<model name="pcie-pci-bridge"/>
<address type="pci" domain="0x0000" bus="0x07" slot="0x00" function="0x0"/>
</controller>
<controller type="pci" index="9" model="pcie-root-port">
<target chassis="9" port="0xa"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x2"/>
</controller>
<interface type="network">
<mac address="52:54:00:2b:6e:20"/>
<source network="default"/>
<model type="virtio"/>
<address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</interface>
<input type="mouse" bus="ps2"/>
<input type="keyboard" bus="ps2"/>
<hostdev mode="subsystem" type="usb" managed="yes">
<source>
<vendor id="0x1038"/>
<product id="0x1294"/>
</source>
<address type="usb" bus="0" port="4"/>
</hostdev>
<source>
<product id="0x1290"/>
</source>
<address type="usb" bus="0" port="5"/>
</hostdev>
<source>
<vendor id="0x08bb"/>
<product id="0x2902"/>
</source>
<address type="usb" bus="0" port="6"/>
</hostdev>
<source>
<vendor id="0x1b1c"/>
<product id="0x0c10"/>
</source>
<address type="usb" bus="0" port="3"/>
</hostdev>
<hostdev mode="subsystem" type="pci" managed="yes">
<source>
<address domain="0x0000" bus="0x0c" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x0c" slot="0x00" function="0x1"/>
</source>
<address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
</hostdev>
<source>
<vendor id="0x046d"/>
<product id="0xc08d"/>
</source>
<address type="usb" bus="0" port="1"/>
</hostdev>
<source>
<vendor id="0x1532"/>
<product id="0x0221"/>
</source>
<address type="usb" bus="0" port="2"/>
</hostdev>
<source>
<product id="0xc539"/>
<address bus="7" device="5"/>
</source>
<address type="usb" bus="0" port="7"/>
</hostdev>
<memballoon model="virtio">
<address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</memballoon>
</devices>
</domain>
Lastly if anyone finds it easier to help me using lstopo, here it is.
Any help is greatly appreciated! I already tried to post a similar question on the Manjaro forums, but with no answers.
My main goal is to pass through every CPU core, except Core 0.
I haven’t done isolcpus yet, because I can’t quite understand that either.
