I'm not going to put much more than 1.35V through my 1700 so I guess I could have gone for something smaller, but I picked the Noctua D15S for its asymmetric design that leaves more room for the first card slot. In the case of the Asus Prime X370 Pro motherboard there's also where the M.2 socket sits.
It requires a Noctua AM4 kit so it's either going to cost you a little extra as an acessory or some time waiting for the free kit coming from them. The D15S comes with a single fan which is fine for most setups, and a second set of fan clips are included just in case. Without a second fan there's also room for RAM sticks with crazy high heatsinks, should you be unfortunate to have bought any such fashion items.
Noctua specifies that the included fan is able to run as low as 300 RPM, but typically for what I've seen with a couple of different motherboards you're likely to have to settle for a RPM floor of around 600. Fortunately it's not audible at that speed either, and as I intend the have chassis fans turn off when the system idles I figure it's a good thing to have some fan spinning inside the case to make the heat move around a bit more. The PSU is also semi-passive.
I think the NF-F12 might be a better comparison then. From what I see they are on par or close to each other in nearly every aspect. But that is only looking at specs given out by the companies themselves. I had noiseblocker fans when 80mm was considered a big fan. ... They didn't last that long and that is why since then I haven't looked at the brand.
Anyway, ripping a noctua fan from the heatsink only makes sense for aesthetics. If it is just about performance, you might want to put the noctua fan back on there. Also, pushpull doesn't do a whole lot for cooling if you are using static pressure fans.
Update: the 1700X is now available with the wraith max cooler. But since the boxed version without the cooler has dropped to 400€, while the version with the cooler costs 460€ (though I've only found at one retailer in germany so far, so this may change), its pretty obvious, that it makes more sense to just buy a proper cooler (though I'm sure the wraith max isn't horrible). I'm just against using the stock cooler, because with my i5 I thought "It can't be THAT bad" and I was wrong. So now I'm using an i5 that doesnt turbo...
