Hmm, here is 2x7950s at1050mhz core and 1250mhz memory with CPU at 4.8ghz. Happy to break 3000.
ahh thanks mate noted! Now back to the cinebench scores
Nice scores! And congrats on getting past the 3000, Im waiting until i can upgrade my psu to start oc'ing my hardware :)
This is because, CB does not allways show´s the correct cpu speed. this happens allot with intel cpu´s.
590cb is not bad for an i5.
Temps are nice ☺
Wow nice gpu you have up there.
But i want to mention, that your FX8350 on stock realy scores low, there 562cb. Mines at stock scores arround 644cb.
Which mobo do you have?
There is 24/7 AIDA64 stable with temps low 60sC max on the hotest core and 24C room temperature.
https://imageshack.com/i/paB5mijtp
Have to try for higher clocks, but when the time is right. :)
scores document updated :)
keep em coming guys, get more people!
and if you get a better score, post again and I will update it!
Nice Thanks ☺
Yeah, I saw latter (after I wrotte comment) in screenshots, my bad.
I noticed I was actually throttling after a while of some testing but this is at stock voltage. I am not sure I have the sufficient cooling to push it past 4.6GHz.
I have an MSI 990FXA-GD65
Time to start overclocking till it hertz again
Running at JEDEC standard? I think you should oc that shit and see how many different BSOD errors you can get.
624cb thats a better number for stock indeed ☺
On your last run your voltage was 1.288 this run its 1.440 which seems high for stock clock. Way nicer score though for sure.
