The time has come once again.
AMD 1100 PT
NVIDIA keynote 1920 PT
NVIDIA 1830 PT
Intel keynotes:
https://www.intel.com/content/www/us/en/events/ces.html
Accenture, Volvo, Delta, x, SiriusXM, Panasonic:
AMD 1100 PT
NVIDIA 1830 PT
Intel keynotes:
What I’m hoping for:
Intel Xeon announcement - Xeon has trailed Epyc in efficiency since 7002 series
AMD Zen 5 EPYC on AM5
Nvidia 5090
AMD 8000 series GPU
https://www.asrockrack.com/general/products.asp#Server
they have a Intel Core™ Ultra 1851 section now, hopefully W880 motherboards are announced this week ![]()
Also i’d love to see 64GB or 96GB ECC UDIMMs announced for W880 or Zen 5/EPYC 4004
“2025 is the year to buy a new PC and move to Windows 11” -Jim Johnson @ Intel
Arrow Lake 200H for gaming laptop
Arrow Lake 200HX for even more gaming laptop
Panther Lake is confirmed on 18A process and running in the wild
Appears to be a consumer SKU based strictly on size presented
ETA: dunno
The amount of new laptop CPUs is overwhelming and confusing… if I need to buy a new laptop it will be a mess to make an informed purchase
damn, that W880D4U-2L2Q look like the perfect board for TrueNAS!
8 SATA, 2x NVME, 25Gbit ![]()
looool where are you seeing this, please send a link
wait what? I see this in your link ![]()
https://www.asrockrack.com/general/productdetail.asp?Model=W880D4U-2L2Q#Specifications
lists core 200 Ultra compatibility
Interested to see the ECC support
Oh snap, my bad for doubting you, its not showing on my side, maybe because im from the UK
ooo i see, can you post a picture of the motherboard if possible, that link just redirects me to the all server motherboards page
Physical Status
Form Factor Micro-ATX
Dimensions 9.6" x 9.6"
Processor System
CPU Supports Intel® Core™ Ultra 200S, 200H, or 200U Series processors
Socket Single Socket LGA 1851
Thermal Design Power 125W
Chipset Intel® W880
System Memory
Supported DIMM Quantity 4 DIMM slots (2DPC)
Supported Type DDR5 288-pin ECC/non-ECC UDIMM
Max. Capacity per DIMM 48GB
Max. DIMM Frequency max. 5600MT/s (2SPC - 0r2r)
max. 4400MT/s (2SPC - 2r2r)
Voltage 1.1V
PCIe Expansion Slots (SLOT7 close to CPU)
PCIe x 16 SLOT6: PCIe5.0 x16 [CPU]*
MCIO1 shared lanes x8 with SLOT6. To enable MCIO1, BIOS settings are required.
PCIe x 4 SLOT4: PCIe5.0 x4 [CPU]
TPM
TPM support 1 (13-pin, SPI)
Other PCIe Expansion Connectors
M.2 slot 1 M-key (PCIe4.0 x4), supports 2280 form factor [CPU]
1 M-key (PCIe4.0 x4), supports 2280 form factor [PCH]
Others MCIO1 (PCIe5.0 x8 or 2 PCIe5.0 x4) [CPU]
MCIO2 (PCIe4.0 x4) [PCH]
SATA/SAS Storage
PCH Built-in Storage Intel® W880 (8 SATA 6Gb/s; RAID 0/1/5/10):
4 SATA 7-pin, 1 Mini-SAS HD
Ethernet
Additional GbE Controller 2 SFP28 (25GbE) by Intel® E830
2 RJ45 (1GbE) by Intel® i210
Server Management
BMC Controller ASPEED AST2600: IPMI2.0 with iKVM and vMedia support
IPMI Dedicated GLAN 1 RJ45 Dedicated IPMI LAN port by Realtek RTL8211F
Graphics
1 DB15 (VGA)
Intel® Integrated Processor Graphics:
1 HDMI, 1 DisplayPort
Rear I/O
UID Button/LED 1 UID button, 1 UID LED
VGA Port 1 DB15 (VGA), 1 HDMI, 1 DisplayPort
Serial Port 1 DB9 (COM)
USB 3.2 Gen1 Port 2 Type-A (USB3.2 Gen1)
RJ45 2 RJ45 (1GbE), 1 dedicated IPMI
Other network connector 2 SFP28 (25GbE)
Internal Connector/Headers
Power Connector 1 Micro-Fit (4-pin, ATX PSU signal) w/ ATX 24-pin adapter cable, 3 (8-pin, ATX 12V) support 12V DC-in
Other Power Connectors 1 (6-pin) for HDD power when using 12V DC-in power source
Auxiliary Panel Header 1 (9-pin): chassis intrusion, system fault LED, LAN1/LAN2 activity LED, locate
System Panel 1 (9-pin): power switch, reset switch, system power LED, HDD activity LED
COM Header 1 (9-pin)
VGA header 1 (15-pin)
Speaker Header 1
Fan Header 7 (4-pin)
Thermal Sensor Header 1
TPM Header 1 (13-pin, SPI)
SGPIO Header 1
SMBus header 1
PMBus header 1
IPMB Header 1
Clear CMOS 1 (2-pin)
Front Lan LED Connector 1
USB 3.2 (Gen1) Header 1 header (19-pin, 2 USB3.2 Gen1)
USB 2.0 Header 1 header (9-pin, 2 USB2.0)
NMI Header 1
LED Indicators
Standby PWR LED 1 (5VSB)
80 Debug Port LED 1
Fan Fail LED 7
BMC heartbeat LED 1
System BIOS
BIOS Type AMI 256Mb SPI Flash ROM
BIOS Features Plug and Play, ACPI 6.4 and above compliance wake up events, SMBIOS 2.3 and above, ASRock Rack Instant Flash
Hardware Monitor
Temperature CPU, PCH, MB temp, Card side temp, TR1, VR, M.2, E830 Temperature Sensing
Fan Fan Tachometer
CPU Quiet Fan (Allow Chassis Fan Speed Auto-Adjust by CPU Temperature)
Fan Multi-Speed Control
Voltage VCORE, GT, VCCSA, VNNAON, VCCIO, 1.8V_CPU, VDD2, 0.82V_PCH, 1.8VSB, 3V, 5V, 12V, BAT, 3VSB, 5VSB
Environment
Temperature Operation temperature: 10°C ~ 35°C / Non operation temperature: -40°C ~ 70°C
Humidity Non operation humidity: 20% ~ 90% ( Non condensing)
How many PCIe lanes do 200H CPUs have ? 20 ?
Why so little / nor improvement ?
:chefs kiss:
unfortunately, until intel takes HEDT seriously with Xeons, these are the highest PCIe Lane count we can get
I’m tempted to replace my AM5 system with this, it would be a decent bump up in performance, and far better connectivity than the EPYC 4004 motherboards offers; 32 usable PCIe lanes actually spread out to more devices my current H13SAE-MF offers.
I’m after the EPYC 4000D4U, but cannot find it anywhere
MCIO for storage
x16 for 2x 100 gig networking
Would make one hell of a NAS
https://www.asrockrack.com/general/productdetail.asp?Model=EPYC4000D4U#Specifications
I just want a raid card, a graphics card, “fast” ≥25GbE networking, and as many MCIO/SlimSAS ports for use with NVME enclosure as possible… and I suppose some SATA as well for the old ODD and miscellaneous drives.
If those MCIO ports could do x2x2x2x2 bifurcation that’d be even better but this isn’t something I’d expect from Intel.
12V power supplies finally available in prosumer/mainstream? Are they available and did anyone run any tests?
This board might be nice way to compare both side by side.
oh that’s interesting, this board can do the ATX12VO standard and has a little mini 6 pin PCIe type power connector to give hdds 5 volts.
hwbusters ran a test of one of the 12VO PSU’s awhile back:
Its funny to look at the unpopulated sections of the PCB where more components should be in the tear down.
