Latest update: Cluster is up and running!!!- slight issues with argument substitution that I need to clean up- will probably push the changes to the git around friday!
Outside of that it seems that FFmpeg has gotten “too smart”. there used to be functionality to blindly decode 10 bit content with the knowledge that the last 2 bits would be truncated.
This was patched out because people would complain about the image issues and blame FFmpeg for it. Looks like I’ll have to reverse this patch in my custom build, presumably this would be done with a set of patch files that do all of the changes I need at build time. Things like disabling superfluous options, activating optimizations paths and so on.
Outside of that, performance is pretty solid so far!! got 8 1080p hevc → 720p H264 streams going per jetson! This roughly lines up with expected performance, tho running under 2 gigs will be a problem. May need to go and do the optane swap options on the m.2 slot.
Also, I’ll post a video at some point, but SEEED technologies makes a POE adapter that supports 23w POE that is Pi/jetson compatiple, and comes in $12 less expensive than the official Rpi foundation unit.
I did have to move the poe 4 pin connector down a little bit- there’s 2 “standard” positions for the poe connector on the hat, and it so happened that this one used the older style. Was a bit gruesome (developer with a soldering iron meme goes here) but works great! Have yet to try and push it beyond the 15W envelope, but hoping to do so at some point. Will eventually push/OC the gpu and encoder/decoder since those are by far the largest bottle necks from my testing
Link: https://www.seeedstudio.com/PoE-HAT-for-ROCK-Pi-4-p-4143.html
I got mine on digikey, but that’s shouldnt matter.
