Let's have a build challenge with the community. Use http://pcpartpicker.com/ ONLY to share the build. It will be really interesting to see what people come up with. There will be a first and second place winner for the best build, and I have a unique way of scoring parts. REMEMBER if you overclock or underclock any part, please specify how and when, if you just say "highest stable", I will choose the average OC I can find online for the particular part.
KEEP IN MIND that this is a challenge thread, not a help me built it thread, and each person will gain points for first and second place based on how they say they would put the system together.
BUILD CHALLENGE RULES
Rule 1: You HAVE to use the AMD-FX 6350 CPU, there will, however, be exceptions if the price of the build come close to the max if you end up using the 6300, or you have a good reason for using that. SOME points will be deducted from your final score if you do it.
Rule 2: You HAVE to use the NZXT Phantom 410 Mid-Tower Case
Rule 3: The PC build MUST include a monitor in the list, and do not include the price of Microsoft Windows
Rule 4: Price Max (monitor included) should NOT exceed 800 USD.
After all of the builds are looked at, benchmarks for different parts will be analyzed to see who's build actually performs the best. If the build is to be overclocked, explain what voltage and cpu ratio you would run the 6350 at. Also, this build focuses on mid range gaming (such as using a 7790).
Ends on 8/12/2013...I will make a video (which will be posted in this thread) showing the winners and why I chose them. GOOD LUCK
aaaaaaaaand GO
If this becomes a thing, I should send out prizes :P
Current Builds..
Cino: http://pcpartpicker.com/p/1qtfJ
Nord496: http://pcpartpicker.com/p/1qtrF
IIIGamebrakrIII : http://pcpartpicker.com/p/1qu7H
trevsstrem : http://pcpartpicker.com/p/1qtFT
Manimal: http://pcpartpicker.com/p/1qWzW
skullabyss : http://pcpartpicker.com/p/1quu1
Crimson Ryoka: http://pcpartpicker.com/p/1quY0
Master_Of_Hearts : http://pcpartpicker.com/user/Master_of_Hearts/saved/2962
Freaksmacker: http://pcpartpicker.com/user/Freaksamcker/saved/299l
RyTak: http://pcpartpicker.com/p/1qvBA
ghettohamster36: http://pcpartpicker.com/p/1qwfB
Lawkodi: http://pcpartpicker.com/user/Lawkodi/saved/2989
LPG: http://pcpartpicker.com/p/1qxaL
Nerd Rage LBC: http://pcpartpicker.com/p/1qx2n
PumpkinsMurder: http://pcpartpicker.com/user/Killerfrenzy96/saved/299X
The_Strifist : http://pcpartpicker.com/p/1qC0V
mcwoppersnaggy: http://pcpartpicker.com/p/1qGIZ
tmlhalo: http://pcpartpicker.com/p/1qTIM
RoryTheFISH: http://pcpartpicker.com/p/1qQyQ
TiamatKiller: http://pcpartpicker.com/p/1qYA4
.NeOZeN. : http://pcpartpicker.com/p/1qZpq
gigabusterEXE: (He did not use pcparticker, the little bastard xD, his build is on page 5: https://teksyndicate.com/forum/build-pc/build-challenge-amd-only-800-dollar-max/149202?page=4
psyscoskyes: http://pcpartpicker.com/p/1r0at
smurfadelis: http://pcpartpicker.com/p/1r0yq
Challenge Music: https://soundcloud.com/adhesivewombat/adhesivewombat-downforce-1
I HAVE DECIDED TO GIVE THE WINNER A 16GB FLASH DRIVE....I WILL MAKE A VIDEO AND UPLOAD IT ON THE 12TH..
Drive specs here...16GB first gen USB 3.0 drive
