Looking for some pointers to create a black hole style type storage solution. Something I can just throw odd sized drives at, then expand the current storage pool over into.
So having a 1TB drive in a system, then throwing a 2TB and expanding, then after a while throwing another 1TB into it to expand further. obviously I’m fine with it being as strong as it’s weakest link.
You can use ZFS to do span just like with LVM… if you arent trying to have some raid solution then just adding each drive as its own vdev will essentially create a spanned volume.
Probably not good with any storage provider. Pretty sure with LVM you’ll lose logical volumes that are on that disk but not the entire volume group. A benefit to LVM is you can configure “important” stuff to mirror to more than one disk, without having to mirror everything.
Seriously, I dont know what you’re doing with this ‘hardware’ but if its not currently running an OS or you are flexible on that, synology hybrid raid is as close as you can get without sacrificing redundancy.
