Absolutely—here’s a drop-in replacement for 02-run-this-script/convert_gridmove_to_kzones.py that scans 01-paste-grids-here/, lists the files, and lets you pick by index 1…N (plus optional --index/--file flags if you want non-interactive):
#!/usr/bin/env python3
Convert GridMove templates (.ini-like text) to KZones layout JSON.
Repo layout (expected):
02-run-this-script/convert_gridmove_to_kzones.py <-- run me
03-kzone-output/
Usage (interactive picker):
python3 convert_gridmove_to_kzones.py
Non-interactive:
python3 convert_gridmove_to_kzones.py --index 1
python3 convert_gridmove_to_kzones.py --file ../01-paste-grids-here/xipergrid2.ini
from __future__ import annotations
import argparse, re, json, sys
from pathlib import Path
from typing import List, Dict
# ---------- Repo helpers --------------------------------------------------------
def repo_root_from_script() -> Path:
# .../02-run-this-script/convert.py -> repo root is parent of parent
return Path(__file__).resolve().parent.parent
def input_dir(root: Path) -> Path:
return root / "01-paste-grids-here"
def output_dir(root: Path) -> Path:
return root / "03-kzone-output"
# ---------- GridMove parser / converter ----------------------------------------
# Treat monitor as percentage space: origin (0,0), size (100,100)
VARS = {
'Monitor1Left': 0.0,
'Monitor1Top': 0.0,
'Monitor1Width': 100.0,
'Monitor1Height': 100.0,
'Monitor1Right': 100.0,
'Monitor1Bottom': 100.0,
SAFE_PATTERN = re.compile(r'^[A-Za-z0-9_\.\+\-\*\/\(\)\s]+$')
def safe_eval(expr: str) -> float:
# Replace [Name] -> Name and evaluate with restricted globals
expr = expr.replace('[','').replace(']','')
if not SAFE_PATTERN.fullmatch(expr):
raise ValueError(f"Unsafe/unsupported expression: {expr}")
return float(eval(expr, {"__builtins__": None}, VARS))
def clamp(v: float, lo: float = 0.0, hi: float = 100.0) -> float:
return max(lo, min(hi, v))
def parse_groups(text: str) -> List[Dict[str, str]]:
groups = []
cur: Dict[str,str] | None = None
for raw in text.splitlines():
line = raw.strip()
if not line or line.startswith(';'):
continue
m = re.match(r'^\[(\d+)\]', line)
if m:
if cur: groups.append(cur)
cur = {}
continue
if cur is None:
continue
kv = re.match(r'^(GridTop|GridBottom|GridLeft|GridRight)\s*=\s*(.+)$', line)
if kv:
cur[kv.group(1)] = kv.group(2)
return groups
def convert(groups: List[Dict[str,str]]):
zones = []
for g in groups:
if not all(k in g for k in ("GridLeft","GridRight","GridTop","GridBottom")):
continue
L = safe_eval(g["GridLeft"])
R = safe_eval(g["GridRight"])
T = safe_eval(g["GridTop"])
B = safe_eval(g["GridBottom"])
x = clamp(min(L, R))
y = clamp(min(T, B))
w = clamp(max(L, R)) - x
h = clamp(max(T, B)) - y
x, y = clamp(x), clamp(y)
w, h = clamp(w), clamp(h)
if w > 0 and h > 0:
zones.append({"x": round(x,3), "y": round(y,3), "width": round(w,3), "height": round(h,3)})
# dedupe by coordinates
uniq = []
seen = set()
for z in zones:
key = (z["x"], z["y"], z["width"], z["height"])
if key not in seen:
seen.add(key)
uniq.append(z)
return uniq
def make_layout(zones, name: str):
return [{
"name": f"{name} (converted)",
"padding": 0,
"zones": zones
# ---------- File selection & I/O -----------------------------------------------
def find_ini_files(indir: Path):
# Prefer .ini/.txt; if none, list any files
files = sorted([p for p in indir.glob("*") if p.is_file() and p.suffix.lower() in (".ini", ".txt")])
if not files:
files = sorted([p for p in indir.glob("*") if p.is_file()])
return files
def choose_file(files):
print("\nFound these files in 01-paste-grids-here:")
for i, p in enumerate(files, 1):
print(f" {i:2d}. {p.name}")
while True:
choice = input(f"Select file [1-{len(files)}] (q to quit): ").strip().lower()
if choice in ("q", "quit", "exit"):
sys.exit(0)
if choice.isdigit():
idx = int(choice)
if 1 <= idx <= len(files):
return files[idx-1]
print("Invalid choice, try again.")
def convert_file(src_path: Path, outdir: Path) -> Path:
text = src_path.read_text(encoding="utf-8", errors="ignore")
groups = parse_groups(text)
zones = convert(groups)
layout = make_layout(zones, src_path.stem)
outdir.mkdir(parents=True, exist_ok=True)
dst = outdir / f"{src_path.stem}_kzones.json"
dst.write_text(json.dumps(layout, indent=2), encoding="utf-8")
print(f"\nConverted: {src_path.name}")
print(f" Groups parsed: {len(groups)}")
print(f" Zones generated (deduped): {len(zones)}")
print(f" Output: {dst}")
return dst
# ---------- CLI ----------------------------------------------------------------
def main(argv=None):
parser = argparse.ArgumentParser(description="GridMove → KZones converter")
parser.add_argument("--index", type=int, help="Pick file by index from 01-paste-grids-here (1..N)")
parser.add_argument("--file", type=str, help="Explicit file path")
args = parser.parse_args(argv)
root = repo_root_from_script()
indir = input_dir(root)
outdir = output_dir(root)
if args.file:
src = Path(args.file)
if not src.is_absolute():
src = (Path.cwd() / src).resolve()
if not src.exists():
print(f"File not found: {src}")
sys.exit(1)
convert_file(src, outdir)
return
files = find_ini_files(indir)
if not files:
print(f"No files found in: {indir}")
print("Put your GridMove .ini files there and re-run.")
sys.exit(1)
if args.index is not None:
idx = args.index
if not (1 <= idx <= len(files)):
print(f"--index must be between 1 and {len(files)}")
sys.exit(1)
src = files[idx-1]
else:
src = choose_file(files)
if __name__ == "__main__":
main()
This script:
Scans 01-paste-grids-here/ for .ini/.txt files.
Prompts you to pick 1…N (or use --index/--file).
Converts the chosen GridMove template into a KZones layout JSON and writes it into 03-kzone-output/.
Want me to also add a “convert all files” option (e.g., enter a to process everything)? I can drop that in too.
