A little late, but this has been on my to do list for too long and it should (fingers crossed) be easy to do.
I have a blog/website of MD (markdown) files. I previously used Hexo to build that into a static HTML site.
Idea here is that since my MD files are in git, if I push this to bitbucket (or wherever) and have an action that will automatically build and then with the build site, push that to the web host!
Presently I use bitbucket and a plain old nginx instance on a linode instance. I will probably need to go back and upgrade that linux distro. As I am sure it’s out of Long term support. So always nice to have a slight detour for a simple job!
I have managed to copy over the MD files from Hexo and it just worked. Which is great!
I’m leaving templates alone, as that seems to be what causes the most headaches when i tried using something else. Maybe just change the CSS a little on the default ananke theme.
Next I was going to see if I could use bitbucket’s build pipeline. But that leaves me wondering how it would transfer the static files it builds to my webserver.
Rather than it “Pushing files”, my webserver can pull it, but it may be easier for my site to just pull the git Repo and build it on any changes.
Bitbucket has deployment keys that allow Read-only access so this may be a safer way to do things for the time being.
