I received an ASUS WRX90 motherboard, and I’ve installed the following:
TR PRO 7985WX
2 x G.SKILL Zeta R5 Neo 128GB (4 x 32GB) ECC Registered DDR5 6400 R-DIMM (PC5 51200)
2 x Samsung 990 PROs (pulled from another working TR PRO system)
1 x NVIDIA RTX 4090 FE (pulled from another working TR PRO system)
I’ve connected CPU_12V(2)_1 and CPU_12V(1)_1 plus the 24-pin, all using CableMod cables, Type 4, Corsair 1500W
Pressing the power button, the system powers on, heatsink gets warm, and the Q-Codes start rolling by as normal. After about 60 seconds, the GeForce RTX logo lights up on the GPU, and then…
Nothing. The last Q-Code displayed is 92 – PCIe Init.
What I’ve tried:
- Pulled all other PCI cards
- Pulled and reseated all memory, and even tried with 4 channels
- Took off heat sync, removed CPU, reseated CPU, reattached heat sync
- Cleared CMOS
- Flashed BIOS to the newest version (early Jan 2024)
- Cleared CMOS again
And yes, I’ve left it here for hours seeing if it was just stuck in memory training, somehow displaying the wrong code.
It never gets past 92. Unfortunately, after having a dead WRX80 ASUS board, and 5 (yes, 5 defective ASUS monitors, various models, shipped from various vendors, all in the course of a year), I’ve come to expect this from ASUS. Against my better judgement I went with this board instead of ASRock – I’m using a Creator WRX80 in my other system and it’s been rock solid.
At this point, unless the brand new HX1500 Corsair Power Supply is somehow defective, or the CableMod cables, there’s nothing left to try. Sounds like it’s time to return the board… and go for AsRock.
Oh, and yes, the standoffs are properly aligned in the case to support the board – I checked this like 5 times before seating it in the Fractal Torrent, and there were no issues. Nothing is being potentially shorted.
Anyone have any suggestions?
