I just was searching if there are any BIOS / etc updates for my Pro WS WRX80E-SAGE SE WIFI
and I noticed they have an new Pro WS WRX80E-SAGE SE WIFI II listed (the support page of the old Pro WS WRX80E-SAGE SE WIFI didn’t load correctly).
vs
I saw in the BIOS manual that they now mention also PBO. From the specs the only difference it seems to be the wifi/bluetooth module. I hope it would be technically possible to also enable PBO on the old motherboard revision, for the owners who have the old revision of the motherboard and want to use this feature.
It looks like they just carried over the memory QVL from the original version. I wish Asus would test/add more 128GB options. They only list a 2933 module from Samsung but I have seen people note that they have been running the Samsung 3200 version in their systems. It would be nice if Asus could confirm and add it to the QVL along with any others (such as NEMIX).
I’m also tuned in. The original model looked to be an awesome board. As Wendell said, one of the nicest boards he’s ever owned. The only draw back as far I as I could see was the lack of PBO. Having access to PBO on this board is going to be awesome. I’m curios if there were physical changes to the board, since you would think it would have been more effective to kick out a bios update instead of manufacturing a new board if that were an option. Also strange to see them put this out now considering Storm Peak is due to launch later this year requiring an all new socket.
Has anyone tried to cross flash the BIOS of the new board on the old one yet? Would be really curious to know if they actually changed something to make PBO work.
The original Asus SAGE board also had the x550 so no change there. As far as I can tell, the only WRX80 board that has the Intel x710 was the Asrock Creator V1 and those are really hard to find now.
Interesting to hear about the V2 - as it seems, it is not on Asus’ Germany website, so I am curious when it will launch here. I can’t find any reference to PBO on their site though? Did anyone get their hands on one yet?
Also, if it is in fact possible to flash the BIOS and enable PBO on the V1, that would be amazing, as the V1 can be found fairly easily at the moment. The V1 seems to currently offer version 1003 while there’s version 0204 available for V2 on the US site. Is there someone who already tried/succeeded with the V2 bios on V1?
I’ve had some problems with v1, I wonder if they made other improvements. I replaced a board and the replacement, the BMC doesn’t work. I don’t recall the original problem. Anyone have a block diagram for either version?
Would it be possible to get PBO installed on the v1 board or is that likely extremely difficult if at all possible?
From what I’ve read, PBO on a 5995wx could be +40% on some benchmarks which would be worthwhile considering for me. Either than or wait for the next generation board and TR family.
OC of Chagall Pro series can be possible only on ASUS WRX80 v2 M/B. If you fail to buy it, try to get ASRock M/B, although MSI WRX80 M/B is known as another candidate for overclocking TR PRO 5000 series.
Thank you @Namth, appreciate the confirmation. It’s disappointing that the v1 board doesn’t have this feature and it’s certainly not cost effective to justify replacing the v1 M/B with the next TR generation rumoured for later in the year. Such is life…
Are there any settings in a V1 M/B BIOS that can improve CPU or general performance in a meaningful way?
In my thoughts, RAM OC is the only option left for increasing performance of your system. T_T But it’s good enough according to workloads.
p.s.) This is my personal view, which can be wrong. I do not belive the rumor of avaliability of TR 7000 series, Storm Peak, at later this year. Even if Storm peak will be announced at Q4 2023, DIY users may wait another a half year from the perspective of the past histories of Threadripper Pro. Moreover, based on another rumors, DIY availability may be delayed up to later 2024 or early 2025. Also, we had better recall the early stages when using Castle Peak with ASUS PRO WRX80 M/B. There were lots of unexpected errors.
Another thing we may consider is workload. In my case, though Chagall Pro is very expensive, I bravely bought 5995wx. Using my own calculating codes used at real researshes, I tested my current system. The bench programs were cut to be short for bench testing. One result of the benchmark tests, 8H running time on 5950x reduced to 2H calculation on 5995WX. In that sense, I can save time! But I know that more time can be saved by OC, because many benchmark tests were executed with various OC techniques on 5950x. So, to unlock the full power of my 5995WX, I bought ASUS Pro WRX80 v2 M/B. And I expect the more time saving, although the V2 M/B is also expensive.
p.s. 2) Irrespective of BIOS versions, it is possible to OC Chagall Pro CPU on V1 M/B, which seems to be bad for real usages from the viewpoint of me.
