@wendell Wow. What a journey attempting to figure out this issue has been. I have tried a lot of different things and still have not figured out what is going on.
At this point due to the fact that the Threadripper platform is the only platform that can do what i need it to do i am just bearing with the slowdowns . The system is functional but it is painful anytime i am installing/transfering data/doing any kind of super varied multitasking.
So I orginally had the Wrx80 Creator borad with the intel nics which is what i wanted. I maanged to get that board to the state my computer is currently in now. Functional but with all of the slow downs in the same areas mentioned above in windows 11. Due to this i suspected it could potentally be a board issue so i went ahead and grabbed an Asus Wrx80 Sage motherboard and an ASrock wrx80 Creator 2.0 revision board( My current board now).
When rigging up the system and runnning many different configs with varied amounts of hardware connected to the system , i was able to replicate the slowdowns that i have been having regardless of which board i was using, and regardless of what components i had connected to the system. I am talking about a lot of component variations here. One stick of ram to many stucks. Standard ram to Ecc ram. Switching PSUs , and nvme drives. SWitching Gpus. Doesnt matter. If the system is pushed enough in windows these issues show up. It doesnât take much pushing either.
I have done limited testing in linux with a bootable drive and the issues seem to not be present there but i still need to do more thorough testing to confirm this. I am not really much of a linux user but i have a good friend that is and we have agreed that with how niche my system is it might be a good idea to actually have a linux install on the ready just for testing purposes alone.
Anyway, Due to the Asrock wrx80 creator board being so fragile and perhaps me being a bit stir crazy after almost a full month of driving 4 hours to microcenter (two hours both ways) and trying different hardware configurations and fighting to get this system to work as desired I finaally landed on the ASrock creator 2.0 motherboard as the board i would end up using not because i wanted that version, but because all the tamporing and hardware swapping apparently caused the Asrock creator board with the intel nics to stop seeing all the ram.
Presently i have continued setting up my system in my desired way with all of the io i typically have connected runnning. Like the original issue i have been trying to diagnose, my system still seems to be incredibly unstable/laggy / inefficent under any kind of intensive multivaried cpu load in windows.
I saw an interesting post on a reddit forum. This indivdual described the issue i am having perfectly. He said the folllowingâŚ
"Iâm kinda confused. My new system with the Threadripper 5995 canât produce a smooth framerate in Windows, just moving stuff around is nauseating. It does fine in games, until it comes to high framerates where it stutters and temporarily stalls framerates to the low 30s. Periodically with no apparent reason.
Someone suggested the fTPU might be causing it so I switched to the discreet TPU, same result.
Itâs in 8 channel memory mode with 512GB installed.
What?
I donât even know what Iâm asking here. Iâm dumbfounded. Any suggestions?"
Like he says above. In games its fine except at random poitns were it may drop. Sometimes simply dragging windows around can be a nauseating if windows is busy thinking about something. It just sounds exactly like my issue. This was his solution that fixed the issue for him. He says:
"Here to clear this up again. I hate leaving posts without conclusions.
Sooooooo⌠actually the whole thing was caused by the Motherboardâs âBMCâ feature. The layer under the whole machine, for KVm access etc. It was also the cause of the kinda weird PCI communication issues I was having.
Disabling BMC has completely fixed the machine."
This post made me excited so i disabled the BMC on my board. The issue still remains. Now i do want to make an important distincttion . This guy has the Asus sage motherboard and apparently that board has a physical switches to disable the bmc and other features which i was aware of when i had the board. From what i can tell i can only do it in bios with the asrock creactor board. I had the sage but never tested disabling the BMC with the switches unfotunately to see if that would make things run better in windows.
I am going to get a hold of my logs and send them to you along with a video dispalying the issues @wendell
I do not really know what i am going to do about this system. I know that this is the only system that is cable of doing the many things that i do in one place. This has all been very overwhelming , costly of my time and money and exahusting. I do appreciate all the help you @wendell and the rest of the forum has offered. Very much appreciated.
