has anyone tried installing ESX on that motherboard ? now that they are removing the intel NIC, I’m not sure if marvell is supported or if I will need to add an external 10gbe card
for an NVME-PCIE card, asus or asrock for the expansion? or it doesn’t matter and the quality is the same as well as compatibility with stuff
no stock anywhere, so I guess it will take me a bit to source one anyway…
