this’ll be a hot minute
On the plus side, the emac being up in the air lets it cool enough so the display stays at 140-190hz. I gotta fuck with that some more.
I just noticed this trinitron has auto degauss for when the lasers get out of focus.
Damn sony.
Surely you don’t mean lasers
Well you know what I mean.
I’m not aware of the innermost gears of a crt lol.
Electron beams are way cooler than lasers
I need to try to play minecraft on this g4 omg.
same thing
Go sleep aremis you’re getting delusional
A e s t h e t i c
I’m not finding much online on why this machine can’t read a damn dvd. So maybe theres something in here?
Nope.
Nothing.
Back to wayback.
oh also checkup on this
theres like 18gb in ports lol
this thread is pure tism
thx bb its what happens when ur high and have nothing to do
I’ll go install OpenBSD on my future file server
good luck echs dee
this thread makes me happy inside
this sun machine makes me angry inside
Aight well this is for sure different than macports. I’m used to a ports management client, but there doesn’t seem to be one?
Equally, I could be retarded. I’m building pkg either way, good nuff.
Lets investigate USB instead.
I’d rather not since OFW/OB boots slow off of it, but idk what else to do.
I’ve been able to boot my solaris disk just fine, the drive works. Just something is up?
is it an oem drive?
i.e. cant read a cd-r/w in a cd-r, that its not dvd into a cd-rw etc
otherwise bad magic number usually means not pointing to correct device/device not found, which would mean try probescsi/probeide w.e. and try the other full path/id, but if it boots the solaris disc from the cdrom name or whatever then it should be mapped correctly
