Hi,
I hope someone here can offer advice on what to do next. I’ve honestly had it with this whole mess and am beginning to doubt the universe itself.
Context:
I had an almost 11-year-old desktop that was my main system, and it worked fine. Then, I decided it was time for a new one in 2023.
Attempt 1:
After some research, I chose the AM5 platform. However, after countless mainboards, power supplies, and RAM kits (each component swapped at least 5 times; this isn’t an exaggeration—I counted 7 mainboards!), I couldn’t get the system stable and gave up in frustration. In hindsight, it was probably the CPU (7800X3D) that was defective.
Having been burned by AM5, I couldn’t trust it anymore. I was able to return most components and sold the rest.
Attempt 2:
Attempt 2 was with Intel 1700, specifically a 14900K. You can probably guess what happened. For a few months, I was happy. Then, the degradation issues began. After two CPU RMAs, which only improved things for 2-3 months each before degrading again, I knew this couldn’t continue. No matter how many microcode updates Intel would end up releasing, I would never be able to trust this system again.
But what to do now? I can’t keep using my old desktop in 2024.
Attempt 3:
So, back to AM5 again it is.
And, of course, the system is unstable. Sigh.
Current components:
- PSU: Seasonic Vertex GX 1000
- GPU: PNY RTX 4080 XLR8
- CPU: AMD 7950X*
- MB: ASRock X870E Taichi*
- RAM Kit 1: (ECC) 2x Kingston KSM56E46BD8KM-48HM*
- RAM Kit 2: (non-ECC) 2x G.SKILL F5-6400J3239G32GX2-TZ5RK
Note: The RAM kits are not installed at the same time! I’ve explained below how I’ve installed and tested them. The system is unstable even with only a single stick of RAM installed!
The PSU, GPU, and G.SKILL RAM have all been in use for over a year with the old Intel system and worked fine, apart from the CPU degradation issues that eventually showed up. So, I assume these components are fine.
The components marked with * are the newly purchased ones, and I’m still within the return window.
The Situation / Problem:
I have the latest stable non-beta firmware on the motherboard (version 3.16 from December 2024).
No matter whether I’m running Windows or Linux (Kernel 6.12.16, 6.13.1), and no matter the RAM configuration, I encounter various errors and crashes:
- Linux: Kernel null pointer dereferences and various other oopses.
- Linux: Sporadic USB disconnects (both USB 2 and USB 3).
- Linux: System crashes with frozen mouse during higher USB 3 activity (reproduced with a 2.5" HDD on a USB-C adapter and NVMe USB C adapter; both work fine on other systems).
- Windows: Sporadic BSODs of all kinds (no specific driver or module), even right after installation during the oobe setup
Previous Attempts:
- Reset UEFI to Defaults (the G.SKILL defaults to 4800 MHz, Kingston to 5200 MHz).
- Used only one RAM stick (Kingston or G.SKILL) in slot A2/B2; this reduced BSOD frequency in Windows, but didn’t stop them completely.
- Used only one RAM stick in A1/B1; this gave me a POST code C5.
- Ran Passmark MemTest v11.2 Pro for 4 hours with both G.SKILL and both Kingston sticks: no errors.
- Ran Y-Cruncher with all tests for 2-3 hours: no errors.
- Ran TM5 with @anta777 ABSOLUT(01102021) for almost 2 hours: no errors
Current Status:
- UEFI is set to defaults, with the latest stable version (3.16 from December 2024).
- Windows 11 24H2 is fully up-to-date, including chipset drivers from the ASRock website.
- One of the G.SKILL sticks (the stable one from the Intel system) is in slot B2, running at 4800 MHz with timings 40/40/40/117 due to UEFI defaults.
- Yesterday, I got two BSOD, which both were unique ones I hadn’t seen before (it disappeared quickly, but I believe it was “PFN List Corrupt”, then during shutdown another one).
Honestly, I’m starting to lose faith in myself and in the modern PC market. I’m about ready to return the AM5 components and give up on the idea of a modern desktop altogether. How can it be that after three build attempts across two platforms with brand-new hardware, something always goes terribly wrong?
What now?
Does anyone have an idea what might be going on here? What else can I do?
