Correct, it’s the same thing just implemented a little differently to plain ivshmem
, we are using ivshmem-doorbell
for interrupt notifications, which is current.
I thought we had been pretty clear… ivshmem was written with only linux in mind, a windows driver was never written for it because there was no use case. I wrote one two months ago which was upstreamed into the official VirtIO git repository shortly after. There is a video of the initial release which will shed light on why a windows driver was never written… they were thinking cloud, massive data, network latency, etc.
In order to continue this work (note, this was all proof of concept at this point and I had not even discovered the NPT problem, let alone the fix) I worked with windows in test signing mode as windows vista 64bit and later will not load a self signed driver unless you’re in test signing mode.
This was fine during the development of the driver, but since Looking Glass needs to run along side applications that contain anti-piracy, anti-cheat, etc… it can’t be run in test signing mode or these applications will refuse to run.
In order to proceed I personally purchased out of my own pocket a driver signing certificate and spent a few weeks jumping through verification hoops to prove my identity. This certificate contains my full name, address and various other chunks of information I would rather remain private which is why I will not release a build that I have signed.
Red Hat has confirmed they will sign a driver and knowing this I dismissed the issue figuring a build would be released in the near future when they are ready… besides still at this point it was a proof of concept, I was literally drawing the frame buffer into a ncurses text console from the guest.
From my point of view at this point, the concept was still to be verified as feasible, as such most things that I wrote were hacked together, no error checking, fixed resolutions, hard coded values, etc…
This is when I discovered the NPT performance issue, I was unaware of this problem up till this point. I had a performance issue I couldn’t nail down and had to spend further time into learning how KVM works, then how AMD SVM works, and then how Qemu works… etc. A huge undertaking in itself.
After fixing it I had no idea the publicity it would receive, and then @wendell mentions to the world that the next step is to “copy the framebuffer to the host”, and here I am sitting on a prototype that did exactly that! So I got in touch with @wendell, shared with him my build at that time which contained all the aforementioned hacky code. This is why that he stated it was rough around the edges… that was an understatement.
The project was too rough to open up to a group of open source developers, it had no clear direction in it’s internal design, too much was hacked together junk just to verify the idea. But the cat was out of the bag… so the last few weeks now I have been working daily, 5-6 hours a day on this project, if I was to guess I would say I have spent over 200 hours on this entire project so far from initial conception.
A few days ago I decided it was time to poke Red Hat again and ask to have a build of the driver released:
From a code perspective, Looking Glass IMO is very stable now, the code has a few things I would like to clean up in it still, but nothing preventing a release anymore. It is lacking some features still, but nothing that will prevent it’s successful usage.
Getting it setup is a little tricky, a few things in windows that needs to be configured first, customization to the VM’s command line, as well as getting permissions correct for starting the ivshmem-server which is used as the shared memory mediator. Documentation on these details needs to be clear and concise before it’s released, not after.
@SgtAwesomesauce is going to document everything he can, but the initial focus will be on a guide to get it up and running as easily as possible. Once this guide is ready, verified to be accurate by @wendell, @celmor and myself we will be in a good position to release. Any additional documentation outside of this initial guide will not hold up the release.
One thing that @wendell is going to try to pursue is obtaining permission from NVidia to enable support for NvFBC on consumer cards. Unless you are “ShadowPlay” or “Steam” the NVidia Capture API refuses to run on consumer cards (even though it can), it will only run on professional cards like Quadros. I have been able to write the code anyway and test since I have a GTX690 I hacked into a Tesla K5000 quite some time ago now. This though will not affect the release of the project, as we have DXGI Desktop Duplication to fall back on if NvFBC can’t be used.
Edit: I forgot to mention a ton of time still needs to go into Qemu, it’s virtual i8042 PS/2 controller has a problem that the mouse stream to de-sync at random, and windows then assumes the mouse is faulty and stops using it (in short, you lose mouse input). This though I have deemed outside of the scope of Looking Glass as I have already proved I can cause this fault with the libvirt Spice viewer also, and as such Looking Glass is not the cause.
If someone want’s to help this project now… go fix that bug! It’s VERY annoying. Likely a race condition with interrupts.
I expect that if that bug is not fixed before Looking Glass is released, the bug is about to get a ton of attention by everyone, since Looking Glass allows you to play games where you move the mouse a ton, you’re quite likely to trigger the fault. This also needs to be in the guide by @SgtAwesomesauce so I don’t get a ton of spurious bug reports.
