Hello!
Task
Wendell tasked me with making a stand for the ICY Dock MB924IP-B in a tiny LianLi case. Ultimately, there would not be enough room, but I did make the design and give it a go!
LianLi Q30X mITX Case:
ICY Dock MB924IP-B:
I wanted to make a holder that would use the 4 holes for the SSD mounting in the bottom of the case. The diagonal bar is to add support so that side doesn’t decide to break off. The front has about a 45 degree stopper to help the stand stay in the case better. Lastly, the top fits the fan in the back and also has hole cut outs for screws.
Files
Object File:
LianLi mITX Case Stand-Mount.zip (18.2 KB)
G-code File:
LianLi mITX Case Stand-Mount.zip (861.5 KB)
Conclusion
The stand fit inside the case, however the other 3D print I made, which was a modified Fractal HDD bay, worked much better & was more practical. This design could’ve potentially worked if there was an inch or so more room from the motherboard for a low-profile cooler.
