Hello!
Task
Wendell tasked me with creating a mount for his LianLi Dynamic case. The mount is to hold an eDP display firmly in place to the glass on the front of the case! @Autumn actually helped me with this one
Design
LianLi 011 Dynamic:
I went simple with this design, and I might add/polish it for future reference, but for now it is done and I’ll put it into the “complete” section. It fits tightly so the piece will not budge unless you use quite a bit of force.
Files
Object File:
LianLi Dynamic Case Insert.zip (1.5 KB)
Gcode File:
LianLi Dynamic Case Insert gcode.zip (87.1 KB)
Result
It came out well I think! The bracket holds in the display pretty firmly and presses it to the glass (gently) and the bottom juts out just enough to connect with the glass to create a sandwhich.
This is a previous version shown in the pictures, but the concept is the same. All I did in new version was add an area to use a screw.
