does anyone make a
10 Port | 8X2.5G+ 2x 10G SFP(VLAN) poe+ Unmanaged Network Switch, with One-Key VLAN
for under 375$ ish 400$ max my budget limit that also covers shipping ?
i found a 6 port ver from
an while i thought about getting 2 with the 2nd as a poe variant with one-key-vlan
which would cover the 4 poe devices i have nicgiga doesn’t have one
because either amazon doesn’t carry one from them or they dont have one at all
so if anyone could point me to one from them an or a similar priced brand like SODOLA or YuanLey
that would be great
the reason i need one like this is it suits my needs
in the past i used to have a 5 port aumox SG305P with poe an one key vlan an it did my setup at the time very well especially the one key vlan solved a lot of issues i had with my network setup an gear
but now that iv upgraded all my pc’s ,AP’s , & home servers to a mix of 2.5 & 10gbit connects a switch that matches is needed
an the nicgiga almost fits the bill but is shy the 4 extra 2.5gbit ports i need.
an while getting two would technicality solve this problem
my overall reason for wanting just one with the stated config an amount of ports
is this , iv got one big cyberpower ups battey backup that covers all eight units of
my network setup an thers not room for a ninth.
an id like to stick with a unmanaged switch but wouldnt be oppesed to a managed on like the
SODOLA 8-Port Gigabit/10G POE Switch Managed, 150W,160Gbps Bandwidth,BT90W Supported Smart Web Managed
thats in my max price range of 400$
i just give up on doing a vlan setup myself because i ovously didnt know how to do it right when i tried with my current
EnGenius Fit EWS2910P-FIT (the one im going to replace)
hence why id prefer a one key vlan option with the stated ports an config.
so can you guys help me out ?
My to be layout after upgrade (currently all running at 1gbit with no vlan)
