1' Foot CAT5 Cable?
Hey Fellow Tekkies,
I have been looking everywhere online for short CAT 5 cable. I don’t know alot about networking but bought a switch for my 4 consoles and I would like to avoid using really long cables. So I was wondering what my options are since 1 foot cabling doesn’t seem to exist.
Thanks
Monoprice has your back: http://www.monoprice.com/product?c_id=102&cp_id=10232&cs_id=1023203&p_id=2113&seq=1&format=2
http://www.ebay.co.uk/itm/5FT-1-5m-Flexible-Retractable-Lan-CAT-5e-Network-Ethernet-Cable-Adjustable-/141831346545?hash=item2105ce9971:g:4JMAAOSw6dNWTE3U
this is most likely garbage but would be tidy
Thanks guys! I think I will go with Summer's or Blanger's suggestion. What's the difference between CAT5e and CAT6?
I just grabbed the very first two entries from googleig "1 Foot Cat5 cable" and posted it for your convenience ;)
Shielding. But for the length of cable you are going for.. and thinking your not aiming at 10Gig/E I say... does not mater.
Pretty extensive explanation of the differences: http://www.cablinginstall.com/articles/2014/12/cat5e-cat6-cat6a-guest-blog.html
have you thought about getting the kit and making your own? its not that difficult
Honestly, with those prices of today.. I can't recommend that. It's more hassle to figure out you messed up one wire in the cable when you look for why the traffic drops when the bandwidth peaks... and so on. Buy them premade has become the goto solution.
@th3z0ne $14?
its not as good as my kit but the testers do work
loads of them 1' long on amazon if he wants premade
Ugh, that testing device makes me cringe. It only says totally broken or conductive. But a bad contact (at the crimped jack) still can conduct good enough for the LED to shine but cause various troubles with high frequencies.
And to be honest... cabling does cost nothing today compared to 20 years back...
If you have the money you should invest in a long cable and a kit to make cables
Cat6 has higher quality outer casing and a piece of plastic in the center of the cable to protect the individual wires from each other. You know how on an old radio you sometimes hear another radio station for a second? cat6 protects the wires from doing that to each other which for a standard user cat6 is probably a waste of money but I don't really care. Gimme the good stuff!
Neither does the stuff to make your own!
You should try it then you have new skill for your CV :)
I've done hundreds of cables at work in the classrooms and server room I look after. I don't even think about the possibility of a marginal connections the chance is so low. You just cut the sleeve, spread the wires (the only real fiddly bit), give them a good shove into the "glass" connector and a firm squeeze on the crimping too.
Oh dear... been crimping cables when it was not cool because everyone got to do it :P
I used to like making my own, now I'm lazy and just use premades of which I have many.
thats not true, not all cat6 cable has that.
Well then people are getting a repacked product and paying for stuff that they aren't getting. I haven't had to buy any Ethernet cable(s) in a while so unless something came out in the last year or so I don't know what you are even saying.
no, thats nonsence
i used 5 boxes of cat 6 on one job alone last year....
it depends on the manufacturer some have it others dont, boxed cat6 doesnt usually but the ones that come on a cable drum do
You should do stand-up. Log in to reality and re-read what I said.
