question if know
which is the correct formatted command to auto-clears page cache, dentries, and inodes
every 30min which is what i need for my laptop’s ram to not be all chewed up during daily use
0 30 * * * sudo sync; echo 3 > /proc/sys/vm/drop_caches
or
*/30 * * * * /usr/bin/sync; echo 3 > /proc/sys/vm/drop_caches
my current crontab -e setting is at midnight like this
0 0 * * * sudo sync; echo 3 > /proc/sys/vm/drop_caches
but that’s to long between flushes , as the ram caching of available an free starts to become inefficient after 12hrs
id preferably like to set the flush for every 6hrs , but the only two examples i found were for 30min
for either time-frame whats the correct format ?
