Hi guys
Because I work with NetApp professionally I have a lot of older equipment like the DS4246 and later DS212C/DS224C shelfs… I use MiniSAS HD cables with the IOM12 modules installed.
Over the years I have just been using one IOM12 module and one SAS cable connected from the shelf to a Linux host.
I learned early on that using the /etc/zfs/vdev_id.conf made sense as it was able to number the disks based on the drive slot… so for example, a typical vdev-id.conf file would look something like:
multipath no
topology sas_direct
phys_per_port 4
slot bay
enclosure_symlinks yes
enclosure_symlinks_prefix shelf
channel 01:00.0 0 0a-
channel 01:00.0 1 0b-
channel 01:00.0 2 0c-
channel 01:00.0 3 0d-
alias intssd03 /dev/disk/by-id/scsi-35002538b0236c670
alias intssd04 /dev/disk/by-id/scsi-35002538b0238d8f0
If you create your zpool using the /dev/disk/by-vdev/… you can get a nice zpool like this:
pool: aggr10
state: ONLINE
scan: resilvered 1.76M in 00:00:01 with 0 errors on Sat Sep 5 15:48:41 2026
config:
NAME STATE READ WRITE CKSUM
aggr10 ONLINE 0 0 0
draid2:21d:24c:1s-0 ONLINE 0 0 0
0c-0 ONLINE 0 0 0
0c-1 ONLINE 0 0 0
0c-2 ONLINE 0 0 0
0c-3 ONLINE 0 0 0
0c-4 ONLINE 0 0 0
0c-5 ONLINE 0 0 0
0c-6 ONLINE 0 0 0
0c-7 ONLINE 0 0 0
0c-8 ONLINE 0 0 0
0c-9 ONLINE 0 0 0
0c-10 ONLINE 0 0 0
0c-11 ONLINE 0 0 0
0c-12 ONLINE 0 0 0
0c-13 ONLINE 0 0 0
0c-14 ONLINE 0 0 0
0c-15 ONLINE 0 0 0
0c-16 ONLINE 0 0 0
0c-17 ONLINE 0 0 0
0c-18 ONLINE 0 0 0
0c-19 ONLINE 0 0 0
0c-20 ONLINE 0 0 0
0c-21 ONLINE 0 0 0
0c-22 ONLINE 0 0 0
0c-23 ONLINE 0 0 0
special
mirror-1 ONLINE 0 0 0
intssd03 ONLINE 0 0 0
intssd04 ONLINE 0 0 0
spares
draid2-0-0 AVAIL
When a disk fails, I know which slot it is installed and I don’t have to fiddle with serial numbers etc..
There is even the possibility to turn on the yellow LED on a drive slot..
Anyway the reason I am creating this post, is that I would like to use multipathing.. so installing another IOM12 module, and connect another SAS cable back to the server…
This is all possible, and with SAS drives it makes some sense, and maybe even a bit better performance.
But I need some help, because while it works fine with the multipathing, I need to import the pool using the /dev/mapper/mpath… and that’s the problem
Do I loose the slot mapping when using mpath? Does anyone know that the “multipath” option in the vdev file actually does? And does it make sense here?
The thing is that vdev has the" “slot bay” option which makes the slot pairing possible, and I would like to keep that some how, while adding mpath…
But is it even possible? And has anyone tried it?
If I find the time, I will do a few tests to see if I can get it working ![]()
