Ashift is 12 on this pool
root@Tower:~# zpool get ashift
NAME PROPERTY VALUE SOURCE
zfs ashift 12 local
Only difference I see (besides the scary SMART warnings) is that the disk currently in the pool (sdg) says it has 512 byte “logical” sectors and 4096 physical sectors, whereas the new drike is 4k for both.
sdg (drive currently in pool, possibly failing):
sdg
root@Tower:~# smartctl -a /dev/sdg
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.1.49-Unraid] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Toshiba N300/MN NAS HDD
Device Model: TOSHIBA HDWG180
Serial Number: X040A0CEFBEG
LU WWN Device Id: 5 000039 a78c888c3
Firmware Version: 0603
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database 7.3/5533
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Oct 16 16:29:13 2023 MST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
See vendor-specific Attribute list for failed Attributes.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 73) The previous self-test completed having
a test element that failed and the test
element that failed is not known.
Total time to complete Offline
data collection: ( 120) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 842) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0
3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 8074
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 43
5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 040 001 050 Pre-fail Always FAILING_NOW 0
8 Seek_Time_Performance 0x0005 100 100 050 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 038 038 000 Old_age Always - 24904
10 Spin_Retry_Count 0x0033 100 100 030 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 42
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 7
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 19
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 506
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 36 (Min/Max 19/47)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 1441804
222 Loaded_Hours 0x0032 039 039 000 Old_age Always - 24509
223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 0
224 Load_Friction 0x0022 100 100 000 Old_age Always - 0
226 Load-in_Time 0x0026 100 100 000 Old_age Always - 538
240 Head_Flying_Hours 0x0001 100 100 001 Pre-fail Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed: unknown failure 90% 24874 0
# 2 Extended offline Completed: unknown failure 90% 24874 0
# 3 Extended offline Completed: unknown failure 90% 24874 0
# 4 Short offline Completed: unknown failure 90% 24863 0
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
sdh (new drive):
sdh
root@Tower:~# smartctl -a /dev/sdh
Model Family: Seagate Enterprise Capacity 3.5 HDD
Device Model: ST8000NM0045-1RL112
Serial Number: ZA1JWGLZ
LU WWN Device Id: 5 000c50 0c6f99f96
Firmware Version: UG07
Sector Size: 4096 bytes logical/physical
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Oct 16 16:29:53 2023 MST
SMART overall-health self-assessment test result: PASSED
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
data collection: ( 567) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
command.
power-saving mode.
recommended polling time: ( 762) minutes.
Conveyance self-test routine
recommended polling time: ( 3) minutes.
SCT capabilities: (0x70bd) SCT Status supported.
SMART Attributes Data Structure revision number: 10
1 Raw_Read_Error_Rate 0x000f 076 064 044 Pre-fail Always - 4574308
3 Spin_Up_Time 0x0003 090 090 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 11
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 092 061 045 Pre-fail Always - 1473853670
9 Power_On_Hours 0x0032 097 097 000 Old_age Always - 3007 (229 249 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 11
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 060 056 040 Old_age Always - 40 (Min/Max 39/43)
191 G-Sense_Error_Rate 0x0032 099 099 000 Old_age Always - 2428
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 83
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 130
194 Temperature_Celsius 0x0022 040 044 000 Old_age Always - 40 (0 26 0 0 0)
195 Hardware_ECC_Recovered 0x001a 006 001 000 Old_age Always - 4574308
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
203 Run_Out_Cancel 0x00b3 100 100 099 Pre-fail Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 2993h+50m+59.202s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 5509984416
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 44512512145
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Unfortunately, I don’t have a super easy way of running that (slackware linux/unRAID). I could give it a go if we really need the info from it though.
What’s puzzling to me is that I’m not sure how much I would actually need to pad the drives by. The drives are actually the same exact size; zfs isn’t telling me just how undersized the new disk is.
No hardware RAID here, just an LSI HBA flashed to IT mode for these particular drives.
From my understanding, ashift=12 would lead to a block size of 4096, which would line up with the 4096 sectors on my new disk. Very strange. I’m still pretty new to ZFS so here are the rest of my properties in case there’s something else I’ve messed up here:
properties
root@Tower:~# zpool get all
zfs size 29.1T -
zfs capacity 75% -
zfs altroot - default
zfs health ONLINE -
zfs guid 17062760427266059542 -
zfs version - default
zfs bootfs - default
zfs delegation on default
zfs autoreplace off default
zfs cachefile - default
zfs failmode wait default
zfs listsnapshots off default
zfs autoexpand on local
zfs dedupratio 1.00x -
zfs free 7.18T -
zfs allocated 21.9T -
zfs readonly off -
zfs ashift 12 local
zfs comment - default
zfs expandsize - -
zfs freeing 0 -
zfs fragmentation 1% -
zfs leaked 0 -
zfs multihost off default
zfs checkpoint - -
zfs load_guid 1792945199749377827 -
zfs autotrim off default
zfs compatibility off default
zfs feature@async_destroy enabled local
zfs feature@empty_bpobj active local
zfs feature@lz4_compress active local
zfs feature@multi_vdev_crash_dump enabled local
zfs feature@spacemap_histogram active local
zfs feature@enabled_txg active local
zfs feature@hole_birth active local
zfs feature@extensible_dataset active local
zfs feature@embedded_data active local
zfs feature@bookmarks enabled local
zfs feature@filesystem_limits enabled local
zfs feature@large_blocks enabled local
zfs feature@large_dnode active local
zfs feature@sha512 enabled local
zfs feature@skein enabled local
zfs feature@edonr enabled local
zfs feature@userobj_accounting active local
zfs feature@encryption enabled local
zfs feature@project_quota active local
zfs feature@device_removal enabled local
zfs feature@obsolete_counts enabled local
zfs feature@zpool_checkpoint enabled local
zfs feature@spacemap_v2 active local
zfs feature@allocation_classes enabled local
zfs feature@resilver_defer enabled local
zfs feature@bookmark_v2 enabled local
zfs feature@redaction_bookmarks enabled local
zfs feature@redacted_datasets enabled local
zfs feature@bookmark_written enabled local
zfs feature@log_spacemap active local
zfs feature@livelist enabled local
zfs feature@device_rebuild enabled local
zfs feature@zstd_compress enabled local
zfs feature@draid enabled local
