Long story short i made a mistake and deleted a entire folder of a project. Realized my mistake immediately stopped the server while considering recovery options.
The most obvious for me would be to restore from a weekly backup to another server, however i was hoping not to loose an entire weeks work.
i have herd it is possible to rollback a zpool to a specific tgx, and was wandering how you would go about this?
have you deleted the folder via file manager or via zfs destroy?
The command “zfs list -t snapshot” shows you whether a snapshot is available for a rollback or not.
Rollback with “zfs rollback -r zpool/home/user@tuesday”
If there is no snapshot you have to restore the data by other means.
