how much benefit would people expect to see adding a special device of optane 905p on a pool of sata SSDs to speed up io? Is this a waste of money or benefit? Run VMs and Kubernetes off this pool in addition to general SMB
I doubt you will see a noticeable impact. Main reason to use it is to bypass the abyssmal HDD random read performance on small stuff. SATA SSDs may not have the bandwidth, but still have NAND flash level of random read/writes.
If your SATA drives are stretched to the limit, offloading some random I/O is useful, but so is adding more drives or memory.
And optional small blocks setting doesn’t apply to ZVOLs, so that won’t be of use to any of your virtual disks either.
And you need at least two of the 905p, because redundancy.
Thanks - I have an HDD pool of 3 Zvols of 6 drive raidz2 HDDs that has mirrored optane special metadata devices with small blocks for small xmp files as well as a separate optane L2arc - and that has really helped the pool.
My SSD pool is 6 zvols of mirrored SSDs with an optane L2arc - but I have been wondering if a special metadata device would be wasted or not - but it seems even for the small level writes being done by K8s and VMs “eating up” the random IO - I wonder if it could be better there.
You neglect the fact that ZFS uses transaction groups (txg) to gather up all writes in memory and basically convert random IO to sequential IO.
Just to give you a perspective for async writes on ZFS: I’ve been playing with various backup methods two weeks ago. Stream of like 5T of user data with everything in it, millions of small files. I was transferring that from 2x striped NVMe 4.0 drives via 10Gbit connection to my pool. Turned out that ZFS was able to write the small stuff faster to my HDDs than the NVMe drives could actually read them.That’s what they call ZFS magic. The magic of transaction groups (txg).
async writes are not a problem you have to deal with, txg’s take care of everything in memory before flushing it to disk as a sequential stream.
Problem starts with sync writes where we can’t gather up random stuff to optimize write pattern on underlying hardware. The application commands to immediately write it to disk although writing single random blocks is really bad even for flash. Workaround being LOG vdev or sync=disabled.
Optane LOG or disabling sync (fastest) all together might be the better approach than throwing money at underlying hardware if indeed sync writes are a thing on your pool.
This is why ZFS performs so well even on HDDs. Because there aren’t thousands of random writes happening in a properly setup pool, it will be one big chunk of data coming from DRAM to disks every 5 seconds (default settings).
That’s how you deal with writes.
You deal with (random) reads by caching stuff in memory.
thanks for this - appreciate the explanation
Also, as I have been digging into my HDD spinning rust pool with triple mirrored intel 900p special metadata device vdev, and I see that the GUI made the special metadata device with ashift of 9 as the intel 900p reports 512byte sectors and cannot be programmed. Whats the consensus on mixed LBA size on metadata device vs spinning rust? I had really wanted this to be 4K to keep everything the same between vdevs.
Late to the party, but adding this for completeness:
According to github com openzfs zfs blob master module zfs arc.c line 7963, this is not the case (sorry can’t include links as a new user):
There is no eviction path from the ARC to the L2ARC. Evictions from the ARC behave as usual, freeing buffers and placing headers on ghost lists. The ARC does not send buffers to the L2ARC during eviction as this would add inflated write latencies for all ARC memory pressure.
Thanks @Impatient_Crustacean . I don’t bother with L2arc myself, so am interested to learn.
Same with special device.
I have since read a Klara blog post about it…
one sec
does this look more like it:
How the L2ARC receives data
Another common misconception about the L2ARC is that it’s fed by ARC cache evictions. This isn’t quite the case. When the ARC is near full, and we are evicting blocks, we cannot afford to wait while we write data to the L2ARC, as that will block forward progress reading in the new data that an application actually wants right now. Instead we feed the L2ARC with blocks when they get near the bottom, making sure to stay ahead of eviction.
Welcome, just keep posting!
Yeah there is an entire CPU thread to feed the L2ARC from so called Ghost MFU and Ghost MRU. Rather efficient mechanic to avoid ARC/DRAM performance being bogged down by disks.
If explaining L2ARC, most people don’t usually mention it (including me) for the sake of simplicity.
Hi
I have a 64tb zvol (67% cap) raidz-2 and ls
and find . -iname
are slow … so the ZFS Special device sounds like it might solve my performance issues.
I ran both:
# zdb -Lbbbs <zpool_name>
and
find . -type f -print0 | xargs -0 ls -l | awk '{ n=int(log($5)/log(2)); if (n<10) { n=10; } size[n]++ } END { for (i in size) printf("%d %d\n", 2^i, size[i]) }' | sort -n | awk 'function human(x) { x[1]/=1024; if (x[1]>=1024) { x[2]++; human(x) } } { a[1]=$1; a[2]=0; human(a); printf("%3d%s: %6d\n", a[1],substr("kMGTEPYZ",a[2]+1,1),$2) }'
but I’m lost at what to do with the output, even chatgpt hasn’t been able to help.
I believe I need find total usuable space using the following: (total allocated space - parity) * some percentage.
@wendell says it should be about 0.3% of the pool size. However, in his example it shows 5tb/172tb which is 3%… which is correct?
From the zdbb Which row(s) should I be looking at for metadata ASIZE?
Thanks
0.3% is assuming ~128-256k records. Your average Zvol will produce massively more metadata depending on the volblocksize. 5T might be correct, depends on the rest of the pool and their record/volblocksize.
special vdev is made for these kinds of Zvols. You can’t really cache that amount of stuff.
Out of curiosity. How wide is your RAIDZ and how much space does the 67T Zvol actually use on the pool?
Its a 10 x 14TB raidz2. Its an older system with dual Xeon v2 and ~250GB RAM
# zfs get recordsize tank
NAME PROPERTY VALUE SOURCE
tank recordsize 128K default
# zfs list
NAME USED AVAIL REFER MOUNTPOINT
tank 62.7T 31.3T 219K /tank
tank/data 38.9T 31.3T 38.9T /tank/data
tank/database 13.1T 31.3T 13.1T /tank/database
tank/surveillance 10.7T 31.3T 10.7T /tank/surveillance
# zpool list -o capacity,alloc,free,expandsize,dedupratio,health
CAP ALLOC FREE EXPANDSZ DEDUP HEALTH
64% 82.3T 45.0T - 1.00x ONLINE
output of zdb
and find
$ zdb -Lbbbs tank
Traversing all blocks ...
82.3T completed (4059MB/s) estimated time remaining: 10691hr 22min 00sec
bp count: 689534270
ganged count: 0
bp logical: 81996814331904 avg: 118916
bp physical: 67222308160000 avg: 97489 compression: 1.22
bp allocated: 90447276257280 avg: 131171 compression: 0.91
bp deduped: 0 ref>1: 0 deduplication: 1.00
Normal class: 90432375140352 used: 64.60%
additional, non-pointer bps of type 0: 8287590
number of (compressed) bytes: number of bps
17: 11464 *
18: 36819 *
19: 7108 *
20: 14007 *
21: 12185 *
22: 8179 *
23: 8118 *
24: 31013 *
25: 14916 *
26: 7324 *
27: 7676 *
28: 9251 *
29: 8500 *
30: 1491 *
31: 13204 *
32: 22783 *
33: 173986 *****
34: 9574 *
35: 12451 *
36: 16165 *
37: 15612 *
38: 13577 *
39: 19061 *
40: 18772 *
41: 17979 *
42: 21008 *
43: 14110 *
44: 12147 *
45: 14700 *
46: 196050 *****
47: 18076 *
48: 21033 *
49: 29458 *
50: 19323 *
51: 29391 *
52: 113753 ***
53: 67465 **
54: 125717 ***
55: 84661 **
56: 84002 **
57: 115790 ***
58: 259506 *******
59: 132745 ****
60: 123229 ***
61: 211594 *****
62: 209710 *****
63: 127805 ***
64: 154614 ****
65: 62928 **
66: 64459 **
67: 80159 **
68: 92735 ***
69: 212592 *****
70: 136472 ****
71: 187823 *****
72: 125797 ***
73: 80840 **
74: 88533 ***
75: 84059 **
76: 76497 **
77: 60183 **
78: 66207 **
79: 62351 **
80: 58502 **
81: 82693 **
82: 57489 **
83: 50976 **
84: 63656 **
85: 57190 **
86: 52961 **
87: 59251 **
88: 75505 **
89: 245231 ******
90: 1725712 ****************************************
91: 201635 *****
92: 79220 **
93: 98902 ***
94: 60891 **
95: 63860 **
96: 77003 **
97: 99050 ***
98: 71553 **
99: 58373 **
100: 46081 **
101: 61569 **
102: 59641 **
103: 46696 **
104: 56727 **
105: 54225 **
106: 74209 **
107: 61631 **
108: 65276 **
109: 51528 **
110: 60918 **
111: 56761 **
112: 73938 **
Dittoed blocks on same vdev: 11889260
Dittoed blocks in same metaslab: 3
Blocks LSIZE PSIZE ASIZE avg comp %Total Type
- - - - - - - unallocated
2 32K 8K 72K 36K 4.00 0.00 object directory
1 128K 12K 72K 72K 10.67 0.00 L1 object array
128 64K 63.5K 4.46M 35.7K 1.01 0.00 L0 object array
129 192K 75.5K 4.54M 36K 2.54 0.00 object array
2 32K 4K 36K 18K 8.00 0.00 packed nvlist
- - - - - - - packed nvlist size
- - - - - - - bpobj
- - - - - - - bpobj header
- - - - - - - SPA space map header
7.33K 117M 29.3M 264M 36.0K 4.00 0.00 L1 SPA space map
74.0K 1.64G 829M 4.78G 66.1K 2.03 0.01 L0 SPA space map
81.3K 1.75G 858M 5.03G 63.4K 2.09 0.01 SPA space map
3 200K 200K 288K 96K 1.00 0.00 ZIL intent log
4 512K 16K 96K 24K 32.00 0.00 L5 DMU dnode
4 512K 16K 96K 24K 32.00 0.00 L4 DMU dnode
4 512K 16K 96K 24K 32.00 0.00 L3 DMU dnode
10 1.25M 248K 780K 78K 5.16 0.00 L2 DMU dnode
4.50K 576M 215M 646M 144K 2.67 0.00 L1 DMU dnode
4.48M 71.7G 17.9G 108G 24.0K 4.00 0.13 L0 DMU dnode
4.48M 72.2G 18.1G 108G 24.1K 3.98 0.13 DMU dnode
5 20K 20K 132K 26.4K 1.00 0.00 DMU objset
- - - - - - - DSL directory
7 3.50K 512 36K 5.14K 7.00 0.00 DSL directory child map
- - - - - - - DSL dataset snap map
8 35K 8K 72K 9K 4.38 0.00 DSL props
- - - - - - - ZFS znode
- - - - - - - ZFS V0 ACL
2 256K 8K 48K 24K 32.00 0.00 L3 ZFS plain file
70.0K 8.75G 282M 1.65G 24.1K 31.79 0.00 L2 ZFS plain file
3.72M 476G 36.3G 142G 38.3K 13.11 0.17 L1 ZFS plain file
640M 74.0T 61.1T 81.9T 131K 1.21 99.60 L0 ZFS plain file
644M 74.5T 61.1T 82.1T 130K 1.22 99.77 ZFS plain file
248K 31.0G 993M 5.81G 24.0K 31.92 0.01 L1 ZFS directory
8.54M 17.1G 6.34G 72.6G 8.50K 2.70 0.09 L0 ZFS directory
8.78M 48.1G 7.31G 78.4G 8.93K 6.58 0.09 ZFS directory
4 2K 2K 96K 24K 1.00 0.00 ZFS master node
4 55K 4K 24K 6K 13.75 0.00 ZFS delete queue
- - - - - - - zvol object
- - - - - - - zvol prop
- - - - - - - other uint8[]
- - - - - - - other uint64[]
- - - - - - - other ZAP
- - - - - - - persistent error log
1 128K 8K 72K 72K 16.00 0.00 SPA history
- - - - - - - SPA history offsets
- - - - - - - Pool properties
- - - - - - - DSL permissions
- - - - - - - ZFS ACL
- - - - - - - ZFS SYSACL
- - - - - - - FUID table
- - - - - - - FUID table size
- - - - - - - DSL dataset next clones
- - - - - - - scan work queue
12 10K 6K 96K 8K 1.67 0.00 ZFS user/group/project used
- - - - - - - ZFS user/group/project quota
- - - - - - - snapshot refcount tags
- - - - - - - DDT ZAP algorithm
- - - - - - - DDT statistics
5.25K 5.51M 5.51M 126M 24K 1.00 0.00 System attributes
- - - - - - - SA master node
4 6K 6K 96K 24K 1.00 0.00 SA attr registration
8 128K 32K 192K 24K 4.00 0.00 SA attr layouts
- - - - - - - scan translations
- - - - - - - deduplicated block
- - - - - - - DSL deadlist map
- - - - - - - DSL deadlist map hdr
- - - - - - - DSL dir clones
- - - - - - - bpobj subobj
- - - - - - - deferred free
- - - - - - - dedup ditto
1 128K 4K 36K 36K 32.00 0.00 L1 other
54 701K 302K 2.64M 50K 2.32 0.00 L0 other
55 829K 306K 2.67M 49.7K 2.71 0.00 other
4 512K 16K 96K 24K 32.00 0.00 L5 Total
4 512K 16K 96K 24K 32.00 0.00 L4 Total
6 768K 24K 144K 24K 32.00 0.00 L3 Total
70.0K 8.76G 282M 1.65G 24.1K 31.77 0.00 L2 Total
3.97M 508G 37.5G 149G 37.5K 13.53 0.18 L1 Total
654M 74.1T 61.1T 82.1T 129K 1.21 99.82 L0 Total
658M 74.6T 61.1T 82.3T 128K 1.22 100.00 Total
Block Size Histogram
block psize lsize asize
size Count Size Cum. Count Size Cum. Count Size Cum.
512: 8.42M 4.21G 4.21G 8.42M 4.21G 4.21G 0 0 0
1K: 9.90M 11.6G 15.9G 9.90M 11.6G 15.9G 0 0 0
2K: 13.0M 33.8G 49.6G 13.0M 33.8G 49.6G 0 0 0
4K: 18.0M 73.7G 123G 6.13M 32.5G 82.1G 0 0 0
8K: 7.15M 68.1G 191G 4.24M 47.1G 129G 38.1M 457G 457G
16K: 7.04M 160G 351G 8.10M 148G 277G 19.4M 466G 923G
32K: 127M 4.48T 4.82T 3.86M 201G 478G 126M 6.81T 7.71T
64K: 27.2M 2.36T 7.18T 9.92M 856G 1.30T 25.2M 2.46T 10.2T
128K: 432M 54.0T 61.1T 586M 73.3T 74.6T 441M 72.1T 82.3T
256K: 0 0 61.1T 0 0 74.6T 872 296M 82.3T
512K: 0 0 61.1T 0 0 74.6T 0 0 82.3T
1M: 0 0 61.1T 0 0 74.6T 0 0 82.3T
2M: 0 0 61.1T 0 0 74.6T 0 0 82.3T
4M: 0 0 61.1T 0 0 74.6T 0 0 82.3T
8M: 0 0 61.1T 0 0 74.6T 0 0 82.3T
16M: 0 0 61.1T 0 0 74.6T 0 0 82.3T
capacity operations bandwidth ---- errors ----
description used avail read write read write read write cksum
tank 82.2T 45.1T 496 0 3.87M 0 0 0 0
raidz2 82.2T 45.1T 496 0 3.87M 0 0 0 0
/dev/mapper/0 49 0 396K 0 0 0 15
/dev/mapper/1 49 0 395K 0 0 0 15
/dev/mapper/2 49 0 397K 0 0 0 15
/dev/mapper/3 49 0 396K 0 0 0 14
/dev/mapper/4 49 0 396K 0 0 0 15
/dev/mapper/5 49 0 396K 0 0 0 16
/dev/mapper/6 49 0 397K 0 0 0 17
/dev/mapper/7 49 0 396K 0 0 0 16
/dev/mapper/8 49 0 396K 0 0 0 14
/dev/mapper/9 49 0 396K 0 0 0 14
$ find . -type f -print0 | xargs -0 ls -l | awk '{ n=int(log($5)/log(2)); if (n<10) { n=10; } size[n]++ } END { for (i in size) printf("%d %d\n", 2^i, size[i]) }' | sort -n | awk 'function human(x) { x[1]/=1024; if (x[1]>=1024) { x[2]++; human(x) } } { a[1]=$1; a[2]=0; human(a); printf("%3d%s: %6d\n", a[1],substr("kMGTEPYZ",a[2]+1,1),$2) }'
1k: 25556693
2k: 9758600
4k: 5124996
8k: 4144854
16k: 2883986
32k: 4097472
64k: 10308032
128k: 1304380
256k: 786550
512k: 305546
1M: 276663
2M: 231548
4M: 113336
8M: 165001
16M: 60267
32M: 77183
64M: 30999
128M: 19839
256M: 23322
512M: 13339
1G: 6948
2G: 5669
4G: 2421
8G: 360
16G: 48
32G: 16
64G: 1
256G: 1
512G: 1
we were talking about the zvol, not the pool. The pool has a pool-wide recordsize which seems to be the default. But the zvol has a volblocksize that is different.
zfs get volblocksize tank/../zvolname
With RAIDZ, especially on wider pools, you waste quite a lot of space when using zvols. On top of the metadata inflation bogging down performance.
edit: I checked the output once more. Block histogram shows mostly 128k stuff, so I assume the zvol runs on 128k. Or there isn’t any zvol and you are just calling the pool a zvol, not sure
Yeah with 67%, pool starts to slow down. You may hit the limit on what your memory can cache. 128k isn’t problematic by any stretch and the rest of the pool is basically non-existent. With 128k as we see on your pool, that’s really average amount of metadata. But with these amounts of data, TBs worth of metadata are normal.
These numbers don’t add up. 10x14 RaidZ2 is 112T raw.
Don’t see volblocksize
, I’m using ZFS on Linux
My vols use the same parameters as my pool, probably newbie configuration on my part.
$ zfs get volblocksize,recordsize {tank, tank/*}
tank volblocksize - -
tank/data volblocksize - -
tank/data recordsize 128K default
tank/database volblocksize - -
tank/database recordsize 128K default
tank/surveillance volblocksize - -
tank/surveillance recordsize 128K default
These are called datasets, not vols or zvols. Zvols are totally different things. That’s why I went into the wrong direction. But we’re on track now
So the entire pool is 128k datasets. That’s good news. No Zvol being a troublemaker.
As edited above, that results in “normal” amounts of metadata. Maybe 0.5%. But even 0.5% is more than your RAM. Pool is reaching capacity limit, fragmentation is probably becoming a concern while 10-wide RAIDZ isn’t good at random IO in the first place and your memory is less able to cache all the stuff while amount of data is increasing.
special vdev will help to some degree. I can’t say how much metadata there is and how you get the 5T. In any case you have to backup and restore to get the metadata into the special vdev. ZFS doesn’t move data by itself. Otherwise ZFS will only allocate new stuff to the special vdev.
The 5tb/172tb was from @wendell 's example in the first post.
My setup is 10 x 14TB. I’m still unsure how to calculate metadata size so I can size the appropriate flash storage.
So does this sounds reasonable for metadata:
as of now: ~64 TiB of data * .005 (0.5%) = 351.8 GiB
max 94 TiB * .005 = 516.7 GiB
ah thank you for clarifying! I must have gotten confused with LVM (device > group > volume) because I was resizing a lvolume to use as L2ARC on nvme drive for this pool.
yes for zfs: vdev > zpools > datasets
not sure how zvols fit into the picture… (looked it up they are block devices sitting atop ZFS for virtual machines)
With 128k recordsize across the pool (and the block histogram clearly shows that >90% is 128k), you can expect around 1G of metadata for each TB. So a mirror of 120GB SSDs will be fine if you stick with 128k. It can’t fix bad random read/write performance on RAIDz, nor does it help with other performance concerns mentioned above, but it will spare your HDDs from reading those ~100GB over and over again when accessing those files.
So this isn’t quite the madness I imagined when I first heard of 67TB Zvol (which is insane, but sometimes needed) and TBs of metadata.
Yeah I was under the impression you got some customer with a 67TB VM disk or running the entire pool as a source for some VM.
500GB is a safe bet in any case if you prefer the 0.5% figure. Pretty much the smallest SATA/NVMe SSD size you can buy anyway.
How do I address those other performance issues?
mirorred Z special device for metadata > 128GB each
random read/write - nature of spinning rust;
for read → add L2ARC
for write → add a ZIL (w/ battery backup) -
what were the other performance issues?
This is my NAS/backup so to speak, I only zfs send/receive
when upgrading disk…
started with disk about a third of the 14TB currently using.
How would you suggest optimizing the datasets if starting from scratch?
data - photos and video and system backups
database - lots of random I/O, large files but lots of random r/w activity
surveillance - images and video, append only
This only helps with so called SYNC writes. And you don’t necessarily need battery backup. If your applications write to the pool via SYNC, LOG/ZIL will speed up things a lot.
Pool gets slower, very slowly starting at 20% capacity. At 80%, expansion is recommended because finding free blocks is now very difficult for a filesystem and blocks will be allocated all over the disk to fit. Fragmentation can get a problem, also exponentially with capacity >50%. Depends on how often you overwrite, delete or modify stuff. zpool list -v
gets you FRAG. You mostly deal with media stuff, generally larger stuff. I don’t expect fragmentation to be the deciding factor.
I had a pool at ~90% capacity with 81% fragmentation. This was my laptops NVMe with a lot of VM disks. It wasn’t feeling like NVMe, I can tell you that much
Mirrors are obviously faster, but that’s a big hit on capacity and probably out of the equation.
Most of your files seem to be larger than 128k. Increasing the recordsize in datasets with purely large files will reduce metadata and overall streamline reads. I’m running 1M recordsize for my media datasets. Files that are written once and never modified.
lots of random I/O and modifying large files generally favor lower recordsizes. If you need to change 2 bits in a large file, the HDD has to read and rewrite the full 128k. But using 8k chunks to store a file of a GB. Well, that’s a lot of metadata and tiny stuff. And you get wasted space because of the stripe size of RAIDZ. It’s always a tradeoff.
So adjust and create datasets according to the kind of data that is stored there. But the default 128k recordsize is generally considered a good balance if you have all kinds of stuff mixed. “No one ever got fired for using 128k”
Getting rid of old snapshots can improve things. Or if you’re running like a thousand of them. It helped me once as it was fragmenting my pool because I had so many of them.
You have a good amount of memory that served your pool well. ARC should handle the most important stuff. You can try using L2ARC and test it. It certainly won’t hurt. You can plug it in and out as you like. Far more easy than adding special vdev. Don’t forget to make it persistent, so L2ARC keeps the stored data even after a reboot.
Bedtime here. I hope I was able to help, there is no perfect solution or single measure to solve all things. special vdev will help, but keep track on the things mentioned above. Filesystems don’t like running at high capacity, especially not copy-on-write filesystems.
Thanks you were very helpful!
Here’s the link for making L2ARC persistent: level1techs dot com/t/persistent-l2arc-on-linux/161928/10 (can’t post links yet)
Adding a 128GB L2ARC on NVME sped up lookups quite a bit, not quite instant but 10s of seconds faster than before.
Going to keep an eye out for 3+TB enterprise flash drives to get high performance and think about mirroring new drives or at least splitting up the workloads to different pools with different config parameters.
