TL;DR Currently using replication of my 6 wide raidz2 single vdev over to a 3 wide raidz1 so I can burn my soon to be old configuration in a fire… or find a virtual lego for it to step on.
My (current) use case is mostly large file (my movie collection), and some random stuff I really don’t wanna loose (that is already stored in multiple places and mediums). Plus a little bit of dabbling in block storage territory (vm’s, containers, containers in VM’s etc). But I have a single m.2 where that usually goes. But mostly large files for now.
So my 10TB HDD 6 wide raidz2… I like the extra security the raidz2 gives me, but 6 wide makes it just that little bit more expensive to expand my pool. Plus the need to expand and the benefits that gives me (more data vdevs) will happen less often. So I’m starting from scratch, but this time, Once More with Feeling. Sorry. I meant with feedback. ![]()
I am moving my data onto some 16TB HDD. Those will end up being my second copy backup. Probably as a pool of mirrors. Easy and cheap to upgrade, plus they will just sit there doing nothing, except the weekly replication.
The real question is how to configure my new pool. I now have eleven 10TB HDDs. I was originally thinking 2 x 5 raidz2, plus one hot spare. It’s only one less wide, but drive by drive as my data hording only get’s worse adds up. Plus I like the idea of needing 3 drives to fail in a single vdev before I loose everything appealing.
But now I’m considering either a 4 or 5 wide raidz1. Two more drives and I could have 3 x 4 raidz1 with a hot spare.
So, 2 x 5 raidz2
or, 2 x 5 raidz1
or, 2 x4 raidz1 (soon to be 3x 4 raidz1)
And I will be using some Optane drives SOMEONE mentioned being a really good deal as a metadata device. I don’t see any benefit with either a log or cache on this pool give my current use case.
And I’d be happy with any of them, but more brains==moreBetter. What would you do? Do those options sound good, and I just need to pick one, or is there something I’m not thinking about?
Happy MLK day my state side people, everyone else, thanks and happy Monday I guess ![]()
