Regards the 2 unconnected sockets, could you use 2 reverse breakout cables?
I don’t know how many sata sockets available on the mobo, but I use a couple of reverse breakouts, and it does throttle the drives via DMI or whatever, but for Rust it’s okay?
Also, can you ZPOOL attach a new drive to an existing raidz member, or is that for mirrors only?
Otherwise might one attach a new drive, then remove the old later on? Like a slower/ 2 step, manual replace?
Oh I think I may have misread you before. You can attach to a raidz member and it will mirror it.
Raidz expansion though is kind of stalled. It needs people to test and review the current WIP code and provide feedback. I have that on my list of things to do and just started looking at it again yesterday.
More like there is a roughed out a PoC but nobody is actively working on it atm. Actually I’m in the process of rebasing the PR on the current master to see how much damage was done by the restructuring that’s been going on as of late. But basically the PR needs design review and testing and then finishing
Heads up, I’ve modified the above script to burn-in my 10TB drives. As per @SgtAwesomesauce I’ve added a run of dd to zero out the disks before running badblocks.
Having spent 1 week burning in just 4x 10TB drives, today I wanted to start the resilvering process. Booted my FreeNAS box that has been off for a while, boom - 2x HDDs are dead
Hobbling on 6x drives, all my parity drives are gone. Wish me luck. Backups? What backups…
pool: big
state: DEGRADED
status: One or more devices is currently being resilvered. The pool will
continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
scan: resilver in progress since Thu Nov 7 19:01:24 2019
2.17T scanned at 1.51G/s, 61.9G issued at 157M/s, 23.0T total
7.48G resilvered, 0.26% done, 1 days 18:35:07 to go
config:
NAME STATE READ WRITE CKSUM
big DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/294440f5-7426-11e7-9d9c-2c4d54456e1f.eli ONLINE 0 0 0
gptid/2a0d7ca7-7426-11e7-9d9c-2c4d54456e1f.eli ONLINE 0 0 0
gptid/d3f98b7d-0162-11ea-864f-b4969130e724.eli ONLINE 0 0 0 (resilvering)
gptid/2ba2a597-7426-11e7-9d9c-2c4d54456e1f.eli ONLINE 0 0 0
gptid/2c63c532-7426-11e7-9d9c-2c4d54456e1f.eli ONLINE 0 0 0
15947505727906227010 UNAVAIL 0 0 0 was /dev/gptid/2d2af08b-7426-11e7-9d9c-2c4d54456e1f.eli
gptid/2ded0a48-7426-11e7-9d9c-2c4d54456e1f.eli ONLINE 0 0 0
gptid/2eb4f9d6-7426-11e7-9d9c-2c4d54456e1f.eli ONLINE 0 0 0
errors: No known data errors
pool: big
state: DEGRADED
2.46T scanned at 418M/s, 443G issued at 73.6M/s, 23.0T total
44.0G resilvered, 1.88% done, 3 days 17:19:43 to go
config:
big DEGRADED 0 0 964K
raidz2-0 DEGRADED 0 0 2.45M
gptid/294440f5-7426-11e7-9d9c-2c4d54456e1f.eli DEGRADED 0 0 0 too many errors (resilvering)
gptid/2a0d7ca7-7426-11e7-9d9c-2c4d54456e1f.eli DEGRADED 0 0 0 too many errors (resilvering)
gptid/2ba2a597-7426-11e7-9d9c-2c4d54456e1f.eli FAULTED 2 78 0 too many errors
gptid/2c63c532-7426-11e7-9d9c-2c4d54456e1f.eli DEGRADED 0 0 0 too many errors (resilvering)
gptid/2ded0a48-7426-11e7-9d9c-2c4d54456e1f.eli DEGRADED 0 0 0 too many errors (resilvering)
gptid/2eb4f9d6-7426-11e7-9d9c-2c4d54456e1f.eli DEGRADED 0 0 0 too many errors (resilvering)
errors: 525903 data errors, use '-v' for a list
