Yeah, Im building a PC and want some opinions
Hey, so how you know from the title I want some opinions about a PC I`m building. Parts:
Corsair Carbide 300R
AMD FX-6300:
Gigabyte GA-970A-D3P:
Corsair Vengeance DDR3 1600MHz 8GB:
Sapphire Radeon R7 260X 2GB
Seagate Barracuda® 1TB:
Corsair CX500M:
I`m buying in sweden so it kinda fits my budget there. So yeah, share your opinions about this machine.
unless your just watching movies and browsing the net that gpu wont be enough infact its about as powerful as standard on board graphics in which case id say go for an apu build
here is what id recomend with an apu instead
http://ca.pcpartpicker.com/user/mon5ter/saved/2TZF
should be a bit cheaper actualy than the am3+ build
see if you can get a 270/7850 instead
+1.  The improvement will be very, very noticeable.
