Xigmatek Nebula C Mini ITX PC Case Review | Tek Syndicate
				</p>
Here we have a very interesting case from Xigmatek. Check out the review for all the details.
Where to buy or check prices:
Amazon: http://amzn.to/1L4RQN2 (note that it comes in white or black)
Specs:
Product Name
Nebula C
Material
SECC with black coatingABS, Steel mesh
Dimension
260 mm (L) x 260 mm (W) x 305 mm (H)
Drive Bay
3.5" Internal 1 + 1 compatible with 2 x 2.5”2.5" Internal 1 + 2 compatible with 1 x 3.5”
Expansion Slot
2 slots
Motherboard Support
Mini-ITX
Power Supply
Standard PS/2(ATX) or EPS
Cooling System
Rear fan: Preinstalled 1 x 120mm XOF black
I/O Panel
USB 3.0 x 2 and HD Audio in/out jacks
Max Graphic card Length
230mm
Max CPU Cooler Hight
80mm
Weight
3.56 kg
This is a companion discussion topic for the original entry at https://teksyndicate.com/videos/xigmatek-nebula-c-mini-itx-pc-case-review
For anyone else wondering, with the motherboard installed there are still fairly large gaps at the bottom combined with some high stand-off's that give what looks to be some good room for airflow. Allso from what i can tell the light is more yellow than orange when lit up.
Here is what It looks like with some parts in it.
Pretty weird case. But I guess it'll work best for HTPCs
