Hi
I usually use spice to connect to a VM over the LAN…I’ve been having some lagginess in the interface, which I can’t fix…So I’ve moved to RDP.
One thing I can’t seem to get working with RDP is usb redirection. Currently I have two windows open. 1 spice remote viewer, redirecting the USB and one I use to control (RDP)
Is it possible to redirect over xfreerdp? I have tried /usb:dbg,dev:0b0e:0420 and this does not seem to work (have to use sudo)
Or possible to send over a usb device without the viewer? I have tried usbredirect --to vm:5900 --device 0b0e:0420 also without success.
Any help much appreciated
