XFR Extended Frequency Range; Incomplete WIP?
Thanks for explaining this.
I thought since you adjusted the speed of the P-State for each core that they were individually controlled.
@catsay
I don’t have any Dry Ice, but I do have some Tangerine Sorbet.
Hmmm, that could make for a tasty overclock
:laughing:
IDK man a few people on Reddit running 1.5V+ have reported some serious degradation quite quickly even with good cooling.
I wouldn’t exactly consider that safe. IDK how widespread that is but I think 1.4 or 1.45 is a safer limit for long term use
BTW I find your results interesting. Seemed in many of the 1600X reviews they were getting 4.0Ghz fairly easily
you can
not you should
1.5 is the max really 1.45 is good max for an everyday’er
That difference of 0.05V is too small to make a difference. Dynamic loading etc will be enough for that to fall within the margin of error for at least 5% of the time.
What’s for certain though is that this will have a direct effect on the CPU’s rated operational lifespan.
Lol no
Even as little as .01 can be the difference between a 1 year lifespan of a chip and a 10 year lifespan of a chip
And .05 is a LOT in overclocking.
If I decide to go with the 1600X and don’t get 3.9-4.0, I’m going to RMA!
Hmm I had another look at it. And you are probably correct.
Voltage steps on Ryzen go in .025 intervals. While negative bias on VCore by the SMU from specified rates can be as much as 0.1125 or less. Depending on load. So you are probably correct. Even setting 1.5V doesn’t mean that the system will actually run at that voltage but instead Bias itself downwards depending on Load conditions.
From My own testing I was able to figure out that.
Up to 3.3GHz voltage to Clock rate ratio is at about 25mV per 100MHz. Super linear.
From 3.3GHz this goes up to 40mV/100Mhz to around 3,5/3.6GHz to about 100mV / 100Mhz going towards 3.8Ghz for stability.
After 3.8Ghz It goes up sharply beyond even that and heat production and current draw rises at multiples of previous. This is the final critical point on Ryzen where I believe the silicon is stable long term. The performance increases per watt spent also become less when testing in Cinebench.
So you are probably correct. But Ryzen also doesn’t seem to work like previous chips at all with the negative voltage bias based on the Base P0 state voltage. So setting 1.5 could really be anything in between 1.39 to 1.49 depending on conditions.
A lot depends on the power supply, not just the mobo’s VRM, but also the on-chip VRM.
The key is load calibration. In high frequency electronics, you don’t just put in a bigger cap to compensate for steep variable current draw. It’s a feedback system. If you run at a lower voltage, even though it’s only very small incremental values, the difference in load calibration can get quite extreme.
Older chip designs depended much more on load calibration from the mobo than newer chips. Load calibration is a big unknown in Ryzen. Overclocking is just not exact science because you don’t know what you’re working with, you can’t know, so you can’t measure or calculate or even determine safe operating brackets. Even mobo manufacturers don’t know the real inner workings of on-chip VRM’s and what the capabilities of the load calibration are. In any case, on those mobos, the VRM’s are pretty beefy, even for the lower tier mobos, so I don’t think it’s a walk in the park.
I just wanna say I hooked up my asrock x370 taichi and r7 1700 ddr4 3200 latency 14 ram… and left everything stock as it could get, wraith stock cooler too. Hwmonitor running during some ultra gaming on Conan Exiles… and a couple of the cpu cores hit 3800 on its own. I haven’t over clocked yet, and ram is running at 2166. The highest voltage that the 1700 went to was 1.41*** on one of the cores.
That is congruent with my experience, I think it is typical performance for the 1700. The 1700 is the chip I would recommend most residential users for the moment, in terms of price/performance ratio. I think the 1800X is expensive for the performance bonus compared to the 1700. I run the 1700 on a B350 and the 1800X on an X370, also a Taichi.
have you overclocked the 1800x? or the ram on that taichi? I am curious what your results were. I could use a crash course too lol.
Yes, constant overclock to 4.1 GHz. Not needing as much voltage as stated above by some people, but there are differences between chips and mobo settings, plus difference between measuring on the board and reading software values. So that can’t really be discussed I feel.
I have no boost enabled on overclock, I didn’t do that on any CPU. It messes up load calibration, and can make a system very unreliable. When overclocking, go for a constant set value, and set the value to the point just before the point where the temps went up with a larger increment in comparison to the steps before, and your chip will have a pretty normal lifespan and no instability during hot days in summer etc
I have ECC ram on the X370 system. I had some issues at first, but now it works. I haven’t really looked into what I can do with the RAM yet. I will try to optimise it like in Wendell’s video, but that’ll have to wait until June or something, don’t have time to get into that now.
I’m a proponent of practical overclocking.
So by no boost, you mean XFR is disabled? If so, what settings in the BIOS are you disabling?
As to the 1700, all the reviewers are saying likewise. But let me say again, I suspect many of these benchmarks are too good as they are from 1800X and 1700Xs that were Nerfed to fulfill inventories. I could be wrong, but time will tell very soon when we start seeing more folks with 1700s that simply won’t OC that high.
@Sensai
Those are very nice results at stock. Do you mean to say that TWO cores had XFR Boost?
on msi bios.
You can set the XFR clock in UEFI, just limit it. XFR will work, but not overshoot the overclock.
That’s a shame, the whole point was to get just a little more above the manual OC at times.
Not a good idea. When overclocking and aiming for the highest performance or stable values, you want to keep your system’s load line calibration on top of the situation.
The current draw when an overclocked CPU ramps up, is quite more spectacular than when a stock clocked CPU ramps up. Voltage is not the only factor in the equation. XFR is not about spiking the voltage and hoping for the best lol. XFR will still work at your set speed, to keep the performance up with variable workloads. A process that requires a lot of performance, will switch cores, cores will independently ramp up and wind down. You could set the XFR clock higher, but when you overclock your system just under the value where the thermals go nuts, you would probably not really want that. It’s another thing if it’s your goal to just set benchmarks and get the highest scores possible, but that’s not real life performance, and it will not guarantee the lifespan of your CPU.
@ zoltan
Yes I am guessing that is what is happening… under the heavy load two were at 3.8 and the others made it to 3.2/3.4… also a thing to note I never mentioned is the lowest all cores ran at was 1.5 … and when i say stock i mean reset bios and go.
I was hoping that XFR above OC would be safe as at least two reviewers stated that they had left the LLC on Auto. This might indicate that the AM4 mainboards are able to automatically manage the voltages with an accuracy that was heretofore unknown.
@Sensai
Now that is really exciting if you look at the potential of this as the process improves.
