So my EVGA X58 SLI LE died on me today. A PWM-voltage-regulate-thingy blew up. Looks like CPU (i7-920) and RAM (Corsair Dom 3x2GB) didn't take any damage, so I'll see if I can sell it.
I just need options and opinions right now.
Should I buy a 'new' X58 motherboard and keep rocking 1st Gen Core i7?
Should I sell CPU and RAM and buy an i5-3570K platform ASAP?
If so, should I buy a Mini-ITX LGA1155 motherboard, since I'm planning on building a M-ITX LAN box with Ivy Bridge CPU later...
I had two WD Black 500GB in RAID0, can I save the data from them with a new motherboard?
Should I buy a boot SSD now that I'm upgrading and need to reinstall the system anyways?
Yes, mostly. But the X58 still has the potential for today's requirements. Unless you either have an 8 year old gaming machine, or have lots of money strapped to your wallet, I'd stick with the X58. In fact, I'm willing to keep mine for the next 5-8 years.
As for your RAID array, If I am not mistaken, you will lose the data going to a new motherboard. I would also say Yes to an SSD. the OCZ Agility 4 drives are cheap and use the Indilinx controller so your speed isn't compression based. just bought a 128GB for $80 off amazon for work.
I still use a i7-950 and I haven't felt the need to upgrade my x58 system yet. Frankly until I see some midranged 6-core cpus I am not gonna upgrade to 2011. Though quad channel is pretty tempting.
I've seen benchmarks where an i5-3570K with 3.8GHz Turbo Mode outperformed an i7 920 @ 4.01 GHz in gaming. But I'd rather save the money and keep to the X58 platform, since I've been planning an upgrade in October.
SSD will be an Intel 520-series 60GB. Only needed for OS and drivers. Got two 500GB for gaming and documents.
But I can NOT recover the data from a RAID0 array with new motherboard? Ah shit. Nothing to come after there I guess...
My crazy overclocking days are over. I won't go any higher than 3.8 GHz when I get the system up and running again. Should be enough to feed a GTX 295 and maybe later a GTX 780 / HD 8970. We'll see.
