X-star DP2414LED Full HD 24" Real 144Hz $169. Too good to be true?
See here for the item. I am wondering if there is something here that explains why the monitor is so cheap. I don't mind TN panels. I can't really find many online who have used this monitor and was hoping somebody here has. Any info would be helpful. keep in mind I am using this currently.
Specs are: Name : X-star DP2414LED
Light source : LED Backlight
Screen Size : 24"(61cm)
Panel Type : TN
Aspect Ratio : Wide 16:9i
Maximum resolution : 1920x1080
Pixel Pitch : 0.276x0.276(mm)
Mode Support : ECO mode 25W
Color Support / color gamut : 16.7M Colors 8Bit RGB data input / sRGB 100%
Luminosity : 350cd/m2
Contrast Ratio : 1000:1
Viewing Angle : 170˚ / 160˚
Response rates : 1ms GTG
Built-in speakers : 5W Stereo speaker
Stand Features : Tilt
VESA : 100x100(mm) / Bolt 4x6(mm)
Interface : Audio IN, HDMI, DVI IN, VGA IN, DC IN
Power consumption : 40W / 25W / 43W/ 0.5W(standby)
EDIT: I went ahead a got it, see first impressions below.
https://forum.teksyndicate.com/t/x-star-dp2414led-full-hd-24-real-144hz-169-too-good-to-be-true/96035/5?u=cosaga
Doesn't sound like its unreasonable especially since it say that there is a sale going on.
I would not be able to live with the TN panel, that is my only gripe.
Then again, this is not from dream-seller that most people purchased from to get their Korean 1440P and 4K panels.
I guess TN doesn't bother me as I have always had a TN panel. I have literally never used an IPS panel.
Dreamseller has it as well just a bit more See here.
I went ahead and bought it. I'd like to know once I get it are there a bunch of tests I can run on it so others in the community can learn based off my either good or bad experience?
Other than seeing how hard I can OC it, plenty of people have posted on the web about getting this panel to 185Hz and 200Hz.
OK So an update.
I got the monitor yesterday, I haven't redone my whole desk to fit it yet, but I did do some minor tests.
Confirmed NO DEAD PIXELS (That I can find using This site)
Runs at 144Hz on Dual Link DVI-D, according to World of Warcraft and Test UFO
Although Test UFO does say every once in a while there is a stuttering issue. But I can't tell so /shrug
I will do more tests in a few days when I get some new things from Amazon on Saturday that I need to redo my desk to accept the 3rd monitor (going up from 2). Including telling you all how to change it from Korean to English.
So far at least this seems to have been a good buy =D
