I bought this item awhile ago when I was upgrading my machine but I couldn't get it to work with the 7th gen Intel CPUs so I just went for a different board. I currently have 3 different BIOS chips for it. 1 stock bios that came with the board, 1 supposedly upgraded chip from eBay (didn't work with 7 gen), and one upgraded chip direct from Asrock (has not been tested). It currently has the eBay chip in it but I can swap them on buyers request and I will send all 3 chips with the board. The board will come in original packaging with all original accessories, manuals, etc, and will be in like new condition. All I've done to it is installed it once then put it back in the box. I am offering $100 for the board. Current retail is $130.
Specs:Summary
Supported CPU
CPU Socket Type
LGA 1151
CPU Type
Xeon E3-1200 v5 / Core i3 / Pentium / Celeron (LGA1151)
Supported CPU Technologies
Turbo Boost Technology 2.0
Chipsets
Chipset
Intel C232
Onboard Video
Onboard Video Chipset
None
Memory
Number of Memory Slots
4×288pin
Memory Standard
DDR4 2133
Maximum Memory Supported
64GB
Channel Supported
Dual Channel
Expansion Slots
PCI Express 3.0 x16
2 x PCI Express 3.0 x16 Slots (PCIE2: x16 mode; PCIE4: x4 mode)*
- Supports NVMe SSD as boot disks
PCI Express x1
3 x PCI Express 3.0 x1 Slots (Flexible PCIe)
Storage Devices
SATA 6Gb/s
6 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1, RAID 5, RAID 10, Intel Rapid Storage Technology enterprise), NCQ, AHCI and Hot Plug
SATA RAID
0/1/5/10
Onboard Audio
Audio Chipset
Realtek ALC1150
Audio Channels
7.1 Channels
Onboard LAN
LAN Chipset
Intel I219-V
Max LAN Speed
10/100/1000Mbps
Rear Panel Ports
PS/2
1 x PS/2 keyboard/mouse port
RJ45
1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
USB 3.0
4 x USB 3.0 Ports (Supports ESD Protection (ASRock Full Spike Protection))
USB 1.1/2.0
1 x USB 2.0 Port (Supports ESD Protection (ASRock Full Spike Protection))
1 x Fatal1ty Mouse Port (USB 2.0) (Supports ESD Protection (ASRock Full Spike Protection))
S/PDIF Out
1 x Optical
Audio Ports
HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Internal I/O Connectors
Onboard USB
2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection (ASRock Full Spike Protection))
1 x USB 3.0 Header (Supports 2 USB 3.0 ports) (Supports ESD Protection (ASRock Full Spike Protection))
Other Connectors
1 x COM Port Header
1 x TPM Header
1 x Power LED and Speaker Header
2 x CPU Fan Connectors (4-pin) (Smart Fan Speed Control)
4 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)*
1 x 24-pin ATX Power Connector
1 x 8-pin 12V Power Connector
1 x PCIe Power Connector
1 x Front Panel Audio Connector
*CPU_FAN1 and CHA_FAN1 can auto detect if 3-pin or 4-pin fan is in use. The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
Physical Spec
Form Factor
ATX
Power Pin
24 Pin
Features
Features
Gaming Armor:
Memory - 15µ Gold Contact in DIMM Slots
VGA Card
- 15µ Gold Contact in VGA PCIe Slot (PCIE2)
- PCIe Power Connector
Internet - Intel LAN
Cooling - XXL Aluminum Alloy Heatsink
Audio - Purity Sound 3
Unique Feature:
ASRock Super Alloy
- Nichicon 12K Platinum Caps (100% Japan made high quality conductive polymer capacitors)
- I/O Armor
- Matte Black PCB
- High Density Glass Fabric PCB
ASRock Live Update & APP Shop
BIOS:
- 128MB AMI UEFI Legal BIOS with multilingual GUI support
- ACPI 5.0 Compliant wake up events
- SMBIOS 2.7 Support
- CPU, GT_CPU, DRAM, VPPM, PCH 1.0V, VCCIO, VCCPLL, VCCSA Voltage Multi-adjustment
Software:
- ASRock F-Stream
- ASRock Disk Health Report
- ASRock USB Key
- ASRock Key Master
- ASRock APP Charger
- ASRock XFast LAN
- ASRock XFast RAM
- ASRock Fast Boot (Fast Boot, Restart to UEFI)*
* These utilities can be downloaded from ASRock Live Update & APP Shop.
UEFI:
- ASRock EZ Mode
- ASRock Full HD UEFI
- ASRock My Favorites in UEFI
- ASRock Instant Flash
- ASRock Internet Flash
- ASRock Crashless BIOS
- ASRock OMG (Online Management Guard)
- ASRock UEFI System Browser
- ASRock UEFI Tech Service
- ASRock Easy RAID Installer
- ASRock Easy Driver Installer
Support CD:
- Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar, XSplit
Hardware Monitor:
- CPU/Chassis temperature sensing
- CPU/Chassis Fan Tachometer
- CPU/Chassis Quiet Fan (Auto adjust chassis fan speed by CPU temperature)
- CPU/Chassis Fan multi-speed control
- Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, GT_CPU, DRAM, VPPM, PCH 1.0V, VCCIO, VCCSA
OS:
- Microsoft Windows 10 64-bit / 8.1 64-bit / 7 32-bit / 7 64-bit
Certifications:
- FCC, CE, WHQL
- ErP/EuP ready (ErP/EuP ready power supply is required)
Packaging
Package Contents
Accessories:
- Quick Installation Guide, Support CD, I/O Shield
- 2 x SATA Data Cables
Pics:
If you have any questions feel free to ask
