WS TRX50 not booting
Hi, so I plugged it in for the first time and the memory training led is still on after 80 mins. Led code is “00”.
WS TRX50
Vcolor 192 GB 6400
9980x
RTX 3070
2 x HX1500i PSUs
Nothing on the screen. I’m looking for a plain video card that I put in a very safe place where it would not be found :joy:, but I don’t think that is going to help.
Any ideas on how to proceed?
If ASUS,
“CPU abnormal”…
In this case I expect you need to update the BIOS to support the 9000-series.
what LEDs are on on the motherboard? can you take a pic showing the whole board? maybe missing a “required” power cable somewhere.
bios flashback may also be in order if you got an “old stock” motherboard.
suggest using the smallest/oldest flash drive you have, format fat32, download the bios, rename it to the right all-caps filename and try bios flashback.
Will upgrade the bios.
I replaced the RTX 3070 with a GT1030 to reduce variables.
Thanks for the error codes… I though that “00” meant no errors… how silly of me :stuck_out_tongue_winking_eye:
Meanwhile a pic of one of my 4 helpers examining the board :ok_hand:. He confirmed all power cables are in and properly seated. The dangling power cables were for the RTX which I just removed.
It is alive!
Thanks!!
