Hello good people. I am building a WRX90 Sage system with 7985WX 512GB of memory and 7 4090’S. Ive already built 2 of these with wrx80 Sage and they are working insanely good. Here tho im having trouble to make the board detect the 7th GPU. I see the asmedia iGPU and i see 6 4090’s Im using 3x Leadex 2000W Platinum PSU’s with the load calculated between the power supplies so its not a power issue (cards are tested 1 by 1 and they work). Does anyone managed to make this motherboard work with 7 GPU’s?
P.S. Last 2 builds i used EK pro single slot Water Blocks (worked perfectly). This time i made the mistake of using Alphacool ES (im the dumb guy that didnt read the block is 24mm thick.) but if you plan on using Alphacool ES you will need custom backplates that are 0.5mm thick to fit the cards.
EDIT: FIxed the issue. It was an almost dead GPU. Faulty JS labeled LDO Regulator was the culprit. Mods can delete the topic
