Intro
So I’ve started to write a web crawler in Python using a couple of libraries to help me achieve my goal. So far so good, however, I’m trying to increase the performance greatly, as I want to crawl across many URL’s, I was hoping there’s a relatively easy way to do this in parallel. It’s only slow as hell at the moment due to the fact that the back end of the website that I’m writing a crawler for is drastically slow, a single dynamic page can take up to a minute to render.
Modules Used
So due to the wide range of problems that I’m trying to solve with one script, I’m including a few modules, here they are:
- os
- csv
- json
- time
- datetime
- requests
- BeautifulSoup
- selenium
- PrettyTable
- BlockingScheduler
Performance Issue
As I’ve said, it can take as long as a minute for a dynamic page to be rendered, then on one of these pages it can take a further 20 or so seconds for the content to be generated, I don’t know why it’s so slow as the back end is out sourced. I cannot do anything to help assist the performance of the back end.
The Problem
As I’ve said, the crawler works fine, I’m just struggling to find a way where I can make multiple crawlers work in parallel. I’ve tried using Threads and I’ve also tried using multiprocessing. I would share the source code of my previous attempts, but I’ve had to delete it because I need to have the software currently running, but I’ll just do some dummy code to demonstrate what I’ve tried below.
Additionally, I would copy and paste the entire thing onto here, it’s just it’s turned into quite a beefy script, it has grown from a few functions to small giant quite quickly.
Code
Here’s what’s currently running:
## run init
init() ## initiate the crawler(s)
## schedule init to run every 8 hours
scheduler = BlockingScheduler()
scheduler.add_job(init, 'interval', hours=8)
scheduler.start()
This is roughly what I’ve tried to do previously:
## run init with different args
def runMe () :
url1 = "http://example.com"
url2 = "http://otherexample.com"
threading.Thread(target=init, args=(url1,)).start()
threading.Thread(target=init, args=(url2,)).start()
scheduler.add_job(runMe, 'interval', hours=8)
scheduler.start()
FYI, in the code I’m currently running, I just have the URL’s in an array elsewhere in the code so that the init function can crawl the same URL’s regardless.
Finally
I’m not at all a pro when it comes to Python, so I know that’s a bit of a disadvantage to start with…
I’m aware to the fact that Python implements a global interpreter lock, hence why I tried to use multiple processes instead of multiple threads, but they still ran in a procedural manner rather than in a more parallel manner.
Does anyone have any idea where I’m going wrong?
Keep in mind, when I was writing this, it was meant to be a quick and dirty script to update server side cache (it’s a totally messed up system) by crawling the front end basically.
Rest Of The Code
So I think it’s worth mentioning that it’s far from finished, I will plan to make this script more dynamic and flexible, in addition to actually implementing good practices as I know at the moment, this code is VERY VERY dirty… All jokes aside, this is my first ever Python program, so it’s been more of a play around with the language more than anything else, I also know that in the code below I’m not using ALL of the stated modules, that’s purely because I plan to use them all, I’m just trying to get the bare bones to work first though.
As I'm not a professional Python developer, a lot of this code is very...
Experimental to say the very least, I'm trying to make a crawler crawl
through dynamically generated pages
import os
import csv
import json
import time
import datetime
import requests
from bs4 import BeautifulSoup
from selenium import webdriver
from prettytable import PrettyTable
from apscheduler.schedulers.blocking import BlockingScheduler
## these are some global variables
MONTHS = ["january","february","march","april","may","june",
"july","august","september","october","november","december"]
URLS = ["example_dump_page","example_two_dump_page","example_three_dump_page"]
BASE_URL = "https://www.demo.com/"
DEV_MODE = False
NUMBER_OF_RUNS = 0
TOTAL_PAGES = 0
TABLE_HEADERS = ['TIMES RUN','URL','BASE URL','PAGE COUNT','MONTH','REMOVE',
'PRICE','FINISHED']
TABLE = PrettyTable(TABLE_HEADERS)
RAW_DATA = {
"headings" : TABLE_HEADERS,
"rows" : []
## the purpose of this function is to get the number of runs
def get_number_of_runs () :
global NUMBER_OF_RUNS
return NUMBER_OF_RUNS
## the purpose of this function is to get the number of pages visited
def get_total_pages () :
global TOTAL_PAGES
return TOTAL_PAGES
## the purpose of this function is to get the table
def get_table () :
global TABLE
return TABLE
## the purpose of this function is to increment the number of runs
def inc_number_of_runs () :
NUMBER_OF_RUNS += 1
## the purpose of this function is to increment the number of pages visited
def inc_total_pages () :
global TOTAL_PAGES
TOTAL_PAGES += 1
## the purpose of this function is to add a row to the table
def inc_table (row) :
global TABLE
global RAW_DATA
TABLE.add_row(row)
RAW_DATA['rows'].append(row)
try :
with open("jsonDump.json", "w") as outfile:
json.dump(RAW_DATA, outfile)
except : print("JSON Dump error.")
## the purpose of this function is to reset the number of pages visited
def reset_total_pages () :
global TOTAL_PAGES
TOTAL_PAGES = 0
## the purpose of this function is to reset the table
def reset_table () :
global TABLE
global TABLE_HEADERS
## the purpose of this function is to help the init function below
def date_string_to_numbers(s) :
arr = s.split("/")
## this is a helper function to get the month name to an int
def monthToNum(shortMonth):
return {'Jan':1,'Feb':2,'Mar':3,'Apr':4,'May':5,'Jun':6,'Jul':7,
'Aug':8,'Sep':9,'Oct':10,'Nov':11,'Dec':12}[shortMonth]
## now get the day, month and year as a string
day = arr[0]
if (int(day) < 10) :
day = "0" + str(day)
month = monthToNum(arr[1][0:3])
if (month < 10) :
month = "0" + str(month)
year = "20" + arr[2]
## return as an int after concatenating the strings
return int(str(year) + str(month) + str(day))
## the purpose of this function is to visit a page and then interact with
## the dom
def interact (url, initUrl, month):
initTest = True
price = 0.00
prTag = ""
rem = "NO"
try:
## find the path to the gekodriver and set it
path = os.path.dirname((os.path.realpath(__file__)))
driver = webdriver.Firefox(path)
## hide the window when possible
driver.minimize_window()
driver.get(BASE_URL + url)
## try to find the button
try :
btn = driver.find_element_by_name('submit')
btn.click()
## clear the console
clear = lambda: os.system('cls' if os.name=='nt' else 'clear')
clear()
## ensure that backend has had a chance to catch up
time.sleep(30.0)
## try to find the price
try :
prTag = driver.find_element_by_class_name("totalPrice")
initTest = True
try : price = float(prTag.get_attribute('innerHTML'))
except : pass
except :
initTest = False
## just close the browser if it doesn't work
except:
driver.close()
initTest = False
## close the browser either way
driver.close()
except:
try:
driver.close()
initTest = False
except:
initTest = False
pass
if (initTest == False or price == 0.0) :
rem = "YES"
numbs = str(get_number_of_runs())
now = datetime.datetime.now()
formatTime = str(now.day) + "/"
formatTime += str(now.month) + "/" + str(now.year) + " - "
formatTime += str(now.hour) + ":" + str(now.minute) + ":"
formatTime += str(now.second)
inc_total_pages()
## add data to the global table
inc_table([
numbs,
url,
initUrl,
get_total_pages(),
month,
rem,
price,
formatTime
## print the global table
print("\n")
print(get_table())
print("\n")
## this is a function which houses the initial logic that's
## required to make this program run
def init ():
## set up global variables
inc_number_of_runs()
reset_total_pages()
reset_table()
current_month = datetime.datetime.today().month - 1
## create the date check
## get the current month
tmpMonth = now.month
if(tmpMonth < 10) :
tmpMonth = "0" + str(tmpMonth)
## get the current day
tmpDay = now.day
if(tmpDay < 10) :
tmpDay = "0" + str(tmpDay)
## add current year onto the above two variables and then parse to int
date_to_beat = int(str(now.year) + str(tmpMonth) + str(tmpDay))
## loop through each month
for i in range(len(MONTHS)) :
## pointless doing/trying out of date pages
if (i < current_month) :
continue
month = MONTHS[i]
## loop through each url
for j in range(len(URLS)) :
url = BASE_URL + URLS[j] + "_" + month + "?removeCache=true"
data = requests.get(url)
soup = BeautifulSoup(data.content, 'html.parser')
rows = soup.find_all("div", {"class":"dealcontainer"});
## loop through each link on the page
for k in range(len(rows)) :
row = rows[k]
## get the link
atag = row.find("a", {"class":"button-solid"})
nestedUrl = atag['href']
## see if it's worth parsing this url or to go onto the next
## link
ptag = row.find("p", {"class":"sub-title"})
dateData = ptag.find("span").text
row_date = date_string_to_numbers(str(dateData))
if (row_date < date_to_beat) :
continue
interact(nestedUrl.replace("/", "", 1), URLS[j], month)
## run init
init()
scheduler.start()
