Hello all,
I asked a few weeks back about potentially going 2.5Gb and a lot of people recommended to just jump straight to 10Gb based on a lot of the switches being ridiculous.
Now i have been searching for a reasonable switch and see there is the DGS-1250-28x which has a mix of gigabit ports and 4 x 10GB ports (i guess uplinks)
Could I use this to upgrade the few necessary devices (like my pc, the media server PC and the container PC + 1 more to 10Gb and have the rest all work at 1Gb as necessary using this switch? Or am I not really understanding how switches work?
Personally Iām holding off on both, hoping that 2.5Gb gets more prevalent over the next year or two. (Come on mikrotik). But if you need more speed now then sfp+ based devices definitely seem like the go. SFP28 is also a possibility for some devices.
Yes that is how switches work. You could have ten clients downloading one gig from a server on a ten gig port, assuming the server could keep up. There is a complicated answer about buffers and packets per second, but for ten clients they donāt really apply.
Awesome.
I was unsure if āuplinksā were only for switch to switch communication, etc and not for other purposes.
Thanks for the help, i think my most cost effective solution is to go that route with mixed style of switch.
I see a lot of AOC sfp cables listing for use either with ubiquiti, cisco or intel is there anything specifically required for DLINK? how would I find what is compatible
You should be fine with anything. The big vendors (Cisco, Juniper, etc) tend to code their switches to only allow their SFP types, maybe with a bypass option that makes a log entry. If you need new DAC cables then maybe look at fs.com.
For host connectivity maybe look at connectx3 cards on ebay? Theyāre quite popular from what Iāve seen.
Thanks again.
Sadly I am in Australia and am at the mercy of whatever will ship here that i dont have to sell both kidneys to pay for (our dollar is sitting around 62c US cents), so i will have to take what i can find rather than be choosey.
Oh, howdy mate. Iām also down in Australia.
The connectx3 cards (CX311A specifically) arenāt too bad at roughly $75 per card off ebay. There are some cheaper cards but some of them run hot, and depend on rackmount server airflow to keep them cool.
I probably should have known considering the vast majority on this forum are probably asleep lolā¦
Awesome thanks, I have saved them on eBay so i have something to look into further when i pull the trigger.
Given how cheap CRS310 and CRS312 are compared to ācomparableā offerings from HPE, Cisco, Dell, etc. are, I donāt think it makes sense for their portfolio to include 2.5G devices.
For example, the CRS312 (4x SFP+ combo, 8x 10G BaseT) has an MSRP of 700-ish. Comparable product from HPE is the InstantOn 1960 12XGT (4x SFP+, 12x 10G BaseT) at 1400⬠retail.
At present prices, if you can afford 10 gig, just get 25. Itās not much more. Only 2.5 if you broke.
