Would a second GPU help?
    Regarding GPUs, I am currently running a GTX 660 2GB card in my pc, other specs are an i5-3570k and 16GB of ram.....etc. I have been adding multiple monitors in order to make work easier and allow me to multitask between a video, PDF documents, games, internet, etc. With the increasing amount of resources needed from GPUs to run more modern games would it make sense to get a secondary GPU? I do not mean get a second GTX 660, reasons being cost, and also I know that if I were to add a second one I would still only have 2GB of VRAM. I have been researching a bit and saw some people get a "lesser" card such as a GT 640 2GB card, and then run their monitor for gaming off of the better card, and all accessory monitors off of the second card.
    Would such a setup improve performance, or ease the load on the 660? Also, would there be conflicting issues with the drivers?
    Please enlighten me, and even if it is not a good idea could you explain as to why and when it may be? Thank you.
If you game on a single monitor, but use the other monitors for productivity or multi-tasking, you won't have a problem. More monitors do not require extra GPU resources - unless you are gaming on a surround setup.
For that, it would be advisable to acquire something like a 7950, which happen to be really expensive right now after a recent boom in purchases.
There would be a conflict between drivers if you switched from Nvidia to AMD. However, sticking with Nvidia would produce less problems. On the other hand, AMD are usually a better choice for the money and AMD eyefinity is probably a little better than Nvidia surround.
Edit:
Let me make it clear. The 660 is fine if you're gaming on a single monitor, but you will want a beefier GPU for a multi-monitor gaming experience.
It isn't necessarily that I want to game across multiple monitors, more that I do multiple games/videos/tasks on multiple monitors. I was looking into getting an R9 280x for the holidays but it was simply not possible with my budget. I thought that adding a second lesser nVidia card may help with some of the load for the time being, especially since I can get them sub $70
That would probably be much more taxing on your RAM, not your GPU. Unless those tasks are GPU heavy, the 660 will be fine.
What kind of load are you talking about if not related to games?  Are you experiencing issues with your current setup?
I'm currently nearly maxing out the VRAM on my 660 in many games. I was hoping to get a 280x this seasons but that seems out of the question. From what it seems it may be best to just put that money towards a better card in the future
