Hi,
I’ve outgrown my current workstation (amd 5950x, 64gb of ram, rtx 3090) and am looking to upgrade to something more capable. At this point in time, the 32 threads are just enough but i’m mainly hit by ram capacity, storage limitations and pcie lanes.
What i am looking for is:
- atleast 1 10gbit nic but i would really like 1 or 2 sfp28 or sfp+ ports.
- enough pci lanes to create a zfspool with 4 m.2 nvme or something similar
- support for 2 gpus, mainly for ML but also for vfio
- atleast 32 threads with current single thread performance
I’ve been chechecking out some ebay listings on epyc and supermicro cpu/mobo combos but am kind of in the middle as they’re shipped from china and do still cost about 1300$ (with 128gb ddr4 in an 8chan config). The epyc 7502p has 64 threads but it’s as good as always slower as the more efficient 7950x 32 thread cpu.
Are there any x670e motherboards or which would support my kind of “requirements” if i would skip on the network cards and go with a 10gbit built-in rj45 port? And can i get away by using the internal 7950x it’s igpu and pass through my rtx 3090 with looking glass? that would also free up some the pcie lane requirements ![]()
I’ve heard that the memory controller on the 7 series ryzen processors is kind of finicky whenever you use all 4 ram slots and expect it to hit 6000mhz so i will most probably op then for a 96GB 2dimm 6000mhz kit if that exists
and upgrade to 192GB and settle with slower speeds whenever i outgrow it.
So TL;DR, should I go for a brand spanking new system (if it can handle the storage needs) or go the slightly neckbeard way and buy some epyc in china ![]()
