Wordpress php help
I have my companys site (wordpress) from the original dev that I’m trying to host on site with a raspberry pi. I’m not a web guy, or code guy for that matter. I’ve got everything set up correctly as far as I can tell but im getting a php error.
ParseError thrown
syntax error, unexpected ‘new’ (T_NEW)
From googling it looks like a syntax issue with php7 but I cant find the script thats causing it. The error doesnt specify anything else. Can someone point me in a direction to look?
Placing this in the index file, should allow you to see what specific errors are being thrown.
ini_set('display_errors', '1');
I found this.
And are you using php 5.6 or php 7?
7, also added that line but page displays the same. Am I doing this wrong?
I just realized I can run the php from terminal to get the error output. Did I mention I’m not a code guy? lel
so the output is now
.PHP Deprecated: Non-static method NextGEN_Gallery_Pro::load_product() should not be called statically in /var/www/html/wp-includes/class-wp-hook.php on line 286
PHP Notice: ob_end_clean(): failed to delete buffer. No buffer to delete in /var/www/html/wp-content/plugins/nextgen-gallery/nggallery.php on line 104
ParseError thrown
syntax error, unexpected 'new' (T_NEW)
From the start of the line 104
            $status = session_status();
            if (in_array($status, array(PHP_SESSION_DISABLED, PHP_SESSION_NONE), TRUE))
                session_write_close();
            fastcgi_finish_request();
        else {
            throw new E_Clean_Exit;
            elseif (!($exception instanceof E_Clean_Exit)) {
                    ob_end_clean();
                    self::print_exception($exception);
I dont know enough to identify the issue. This appears to just be a plugin issue though so maybe renaming the dir will at least get it running?
Well, all that did is break the web server.
@anon75264233 Thanks for pointing me in the right direction. It was a bad plugin and it looks like I need to update wordpress anyway but im at least able to get into the admin now!
Looks like it’s an error in the way it’s trying to report an error (at least for php7). When your error reporting is causing errors… good times~ /s
I was able to get the site mostly working. I am still having issues with pages not working but the php seems to be ok now. I just have to work through the little problems as they come via google but im at least getting somewhere now.
Glad you somewhat got it!
Seems like a plugin which would only work with PHP 5.6.
If you downgrade your version of php in use that might resolve it.
