WNC does not have a valid IP configuration?
Hi Everyone , im new around here, didnt know where to introduce myself so im skipping that for the moment.
I need your help with some conection issues. I have a router that is shared by 3 people at home, everyone uses a direct wire connection. The problem is that mine pc loses the connection every now and then because the ip for my PC has not been set appropriately. Question is, what could cause this? a bad Wndows network configuration or because of a bad configured router?
THanks in advance and im looking forward to use this site more often
Saludos
Might be a bad cable. What you can do is set a static ip, see if that will work.
thanks for the prompt reply. I recently bought this 30 feet internet cable so that shouldnt be the problem. I dont know how to set an static ip, i will look it up.
You're welcome, open up your network and sharing center, click on your network connection then click properties then double click on ipv4. you can set the static ip there
i got there but I dont know what to do next. Could you tell me how to set the static ip?
http://blog.mclaughlinsoftware.com/2009/11/26/windows-7-static-ip/
Also make sure your network address is the same as the routers. Network portion for a class C address (which just about all home networks use) is like: 192.168.1.x
The x would be the section you can edit.
Ok . now i dont know how to access my router to see my DNS address , i can only see it with the CMD. Can I put any random number after the x, right? I ckecked my ipconfig /all in cmd and my  Default Gateway is the same as the DNS Server IP Address. So i guess i need to put only one preferred DNS Server, because idk what to put in the alternate DNS server.
I appreciate your help
Any random number, just need to make sure it isn't the same as any of the other computers.
you can use the Google DNS. 8.8.8.8 for the primary, and the alternative one would be 8.8.4.4
What router to you have?
I used the same IP of Default Gateway  for the Primary DNS and left the Alternate DNS empty, so far the connection seems to be working with no problems. If I have any issues I will try the IPs you gave me.
My router is a Zhone Model: 6218-I2-302-0TS. I dont know how to access the router from my PC, do you know how?
Thanks again
Just enter the IP address of your router into a browser. It will ask you for a user and password
Some of the defaults are
Username: user
Password: user
Username: Admin
Password: Admin
Username Admin
Password: Password
those are some of the defaults
