Hello! So I am not sure what I am looking for so I will explain my situation.
I am at university and I have two other roommates in an apartment they both have a wired connection to the router and I do not. The problem is that our isp (telus) is rather shit with help. My room is >15m from the router and when my roommates are home I can barley load the Google homepage in under 10min. I thought about getting a long Ethernet cable but having it run through the living room and kitchen is not really doable. However, if I go and park by the router and connect my laptop via Ethernet while they are both gaming I can still get 2mbps download speeds. So I am 99% sure the wireless on the router is just crap.
So, what I am wondering is if some device exists that I can plug into an Ethernet port on the router that I can then wirelessly connect to my PC so I would essentially have my own wired connection. I should also mention even sitting by the router the wireless connection is junk.
My wireless adapter is ASUS PCE-N53 in my previous place I had no problem with internet speeds either.
