I wanted to know if anyone has experience with 4k HDMI wireless adapters used for gaming…
Anyone know of a good product or ones to avoid from experience.
I can run a cable, but this would be a cleaner option.
TIL that wireless HDMI adapters exist.
But I did some searching online and found that a lot of cheap ones out there actually use wifi for another casting software for data transmission and I bet those are the ones with very poor quality and performance.
Most gamers care about latency and frequency both of which are much more difficult when you add layers and complexity to the data transmission. Even this DVDO model which seems like one of the few that actually work they way you’d want one to work only boasts [email protected]
Good luck and I hope you find something that works for you, but I’m skeptical
