Hey everybody. Great to see you as usual.
I’m looking for some guidance on an issue I am having attempting to setup Wireguard on my home server. I am unsure which information is pertinent, so instead of flooding this post with potentially unnecessary information, I will provide some details on my setup and what I can and cannot do with Wireguard at present.
I am trying to access my home server with an android device from outside the network to access things like Home Assistant, Sonarr/Radarr, etc.
Currently I am stuck at only being able to access http://pi.hole/admin/
and my router at 192.168.68.1
when using the Wireguard VPN on my android device. Any attempt to browse to another in home service results in a failure to load.
I am running Wireguard with docker-compose alongside PiHole (and many other containers). This is my compose.yaml
containing these two services:
services:
wireguard:
image: lscr.io/linuxserver/wireguard:latest
container_name: wireguard
env_file: .env
cap_add:
- NET_ADMIN
environment:
PUID: ${PUID}
PGID: ${PGID}
TZ: ${TZ}
PEERS: 2
PERSISTENTKEEPALIVE_PEERS: all
volumes:
- ./docker/wireguard/config:/config
ports:
- "51820:51820/udp"
sysctls:
- net.ipv4.conf.all.src_valid_mark=1
restart: unless-stopped
pihole:
container_name: pihole
image: pihole/pihole:latest
env_file: .env
network_mode: "host"
environment:
WEBPASSWORD: *****
FTLCONF_LOCAL_IPV4: 192.168.68.2
TZ: ${TZ}
PUID: ${PUID}
PGID: ${PGID}
volumes:
- ./docker/pihole/etc-pihole:/etc/pihole
- ./docker/pihole/etc-dnsmasq.d:/etc/dnsmasq.d
cap_add:
- NET_ADMIN
This is what’s inside my wg0.conf
[Interface]
Address = 10.13.13.1
ListenPort = 51820
PrivateKey = *****
PostUp = iptables -A FORWARD -i %i -j ACCEPT; iptables -A FORWARD -o %i -j ACCEPT; iptables -t nat -A POSTROUTING -o eth+ -j MASQUERADE
PostDown = iptables -D FORWARD -i %i -j ACCEPT; iptables -D FORWARD -o %i -j ACCEPT; iptables -t nat -D POSTROUTING -o eth+ -j MASQUERADE
[Peer]
# peer1
PublicKey = *****
PresharedKey = *****
AllowedIPs = 10.13.13.2/32
PersistentKeepalive = 25
[Peer]
# peer2
PublicKey = *****
AllowedIPs = 10.13.13.3/32
I know there is plenty more information I could provide and there are plenty of things I have tried but I wouldn’t know what and what isn’t important as I’m still learning a great deal. More than happy to provide any information you require for help troubleshoot this issue
Kindest regards <3
