I’m wondering if anyone has experience with wireguard running on podman, could help me out.
It was so easy to run on docker, I was not expecting this to be so difficult with podman.
The whole experiences has been weird. I had it running multiple time and then for some reason it stopped ! I guess I’m missing something on the networking side but I can’t figure it out what.
I have forward and masquerade enable on the host NIC.
The pod is running with:
–sysctl=“net.ipv4.conf.all.src_valid_mark=1”
–sysctl=“net.ipv4.conf.all.forwarding=1”
I also enable firewalld logs. But I’m not getting anything.
Sure
I’m using linuxserver container and I followed Pro Custodibus doc to deploy it.
I have been using linuxserver wireguard container for quite some time now with Docker. That’s why I kept the same.
Failing logs are something else. The container run without any issue.
.:53
CoreDNS-1.10.0
linux/amd64, go1.19.1, 596a9f9
[#] ip link add wg0 type wireguard
[#] wg setconf wg0 /dev/fd/63
[#] ip -4 address add 10.13.13.1 dev wg0
[#] ip link set mtu 1420 up dev wg0
[#] ip -4 route add 10.13.13.2/32 dev wg0
[#] iptables -A FORWARD -i wg0 -j ACCEPT; iptables -A FORWARD -o wg0 -j ACCEPT; iptables -t nat -A POSTROUTING -o eth+ -j MASQUERADE
[ls.io-init] done.
I enabled firewalld “denied” logs but did not get any. I might have missed something there. Because I seems weird that there is not way to enable debug log.
I did run tcpdump outside the container to be sure about the NIC. Because podman create interfaces like docker basically but it is not using them. Everything go through ens18.
I did not run tcpdump inside the container though.
Then from one google search to the other, I added more options to the conf until what I have now.
Right now I’m running the container as root. I don’t think it’s possible to run rootless because of the network component. But please let me know if otherwise. (I tried but could not wake it work)
And like I said in my first post using my custom network setting the container lan subnet is not working.
I noticed that the container create an interface ’ eth0@if124’.
When using the default network subnet 10.13.13.0/24 this interface use this IP: 10.88.0.50/16
Not the same network.
When I use a custom network, in my case 10.15.15.0/24 gateway 10.15.15.1.
This interface instead of having an IP in 10.88.0.0/16 it’s getting an IP from the container subnet. 10.15.15.0/24 (Is it why the client cannot connect when using something else than the default network?)
At the beginning, I created another zone to set the masquerade and forward, With the podman NIC. But it does not make a difference everything goes through ens18.
The other thing I cannot make sense of are the firewall-cmd forward rule. I can take them off and reload firewald and the connection remains.
I’m basically trying to make sense of all this. I added a lot of stuff and I would like to know what basically is necessary.
So in case this might interest someone.
Podman and wire guard is working fine.
The container needs to run as root other wise the network forwarding will not happen. I’ll keep digging with the network + rootless container, I might have miss something.
Anyway.
If you want DNS resolution make sure to allow the container IP (default PEERSDNS=auto point at the container IP, but you can also specify your DNS IP and pass it in the allowed IPs).
For both cases, if you want to use a custom network keep in mind that the container will use the first IP of your network, so don’t assign it to the gateway.
The default network that comes with podman is bridged to the host NIC. There might be a way to get a more secure setup with a different option and a specific zone. So that you don’t apply the rule to the default public zone.
So far I have been unsuccessful. I’ll update the post if I find something.
In my podman compose file. Suddenly, all of my wireguard forwarding issues went away.
I want to write a longer blog post about my setup because it’s… fascinating how easy it is to forward ports with an indirection setup on the a server with SNAT/DNAT configured. Before I do that, I’m hoping to solve one other desired feature: I’d love the wireguard to accept local connections to the server as well when available so that I can minimise connection times if there’s a direct connection to the server available. This would mean lan-level connection to game servers in a lan party context, for instance.
You might also notice the mtu specification. I’m not sure it’s 100% necessary, but logically it would make sense for the mtu setting to match that of the wireguard mtu + leniency of the packet size based on the WG specification. Otherwise, the podman container has a stupidly high MTU setting which might cause connection issues in certain circumstances.
