I had an Aorus 17G KD as a backup device whenever I am traveling to continue my work/gaming.
I didn’t update anything for many months, maybe a year (because I was not using it). So on January of this Year, I opened it and Windows, Aorus and Intel, welcomed me with a ton of updates and I decided to do it.
Install and Restart aaaaaand… it’s gone.
How it reacts:
- Blackscreen for a while and then AORUS logo (just that)
- Blackscreen with RGB Keyboard open.
- Blackscreen for a while, to Aorus, to Windows Automatic Repair (stays there for ever. Left it open for 2 days once)
- HAPPENED ONCE, The laptop just booted. But only for once.
I am able to access BIOS 80% of the time but BIOS is another problem now.
There is no GUI. My BIOS now is the good old Grey/Blue that I remember on my computed 25 years ago with limited settings. Sadly there is not Flash option to flash the bios again.
On the frontpage it says " ME Firmware Version 0.0.0.0 " so something related to Intel I believe is the problem? Dunno.
I tried all traditional Fixes. Reseting, CMOS Reset, Bios Reset, Unplugging the NVMe, unplugging RAM to try only one stick and more.
Everything points to BIOS (and ME) as the problem after Windows Update and to Re-flash it to resurrect my RGB paperweight.
I found out that almost exactly the same problem happened to Aorus G5 and G6 (nobody with 17G Sadly) so the Fix would be easy. Follow the official Aorus fix and I will be ready to go.
After extracting the EXE that you get with 17G Bios, I got my hands on a ROM file. The problem now is that Gigabyte’s Fix doesn’t support ROM bios so I had to find another way.
After some digging around all kind of laptops and bios, I ended up with AMI Firmware Update Utility for American Megatrends motherboards.
Downloaded the tool, booted, typed the command to flash the ROM Bios and … error.
“46 - Error: Problem Getting flash information.” Google and reddit searches were not helpful and I tried my luck with Gemini which said that my intel ME chip is bricked and it needs reprogramming using CH341A ( I don’t even know how to use such a tool). I even tried a newer version of AMI Update and now I was able to start the re-flash but I get the error 43 and error C1 after trying to update MER.
So, what am I supposed to do now ?
Any help ?
I am in BIG need of this laptop now.**
